Part Number: TM4C129ENCPDT
Other Parts Discussed in Thread: CCSTUDIO
I am trying to install the ARM GCC add-on through the CCS App Center.
However, I get the following error:
And this is the relevant log file:
!SESSION 2024-08-14 09:10:57.705 ----------------------------------------------- eclipse.buildId=4.23.0.I20220308-0310 java.version=11.0.13 java.vendor=Eclipse Adoptium BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US Framework arguments: -product com.ti.ccstudio.branding.product Command-line arguments: -os win32 -ws win32 -arch x86_64 -product com.ti.ccstudio.branding.product This is a continuation of log file C:\Users\eric.wu\workspace_v12\.metadata\.bak_0.log Created Time: 2024-08-14 09:12:37.619 !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:37.620 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:37.643 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:37.643 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:37.643 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:37.643 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:37.659 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:37.660 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:37.660 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:37.693 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:37.868 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:37.876 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:37.881 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/artifacts.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:37.890 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:37.894 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/content.xml.xz, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:37.901 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:37.923 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:37.939 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:37.989 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:38.025 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:12:38.223 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/artifacts.jar. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:38.335 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:38.354 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:38.386 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:38.387 !MESSAGE Connection to http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/site.xml failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:38.684 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:38.700 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:38.728 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:38.914 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:38.931 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/artifacts.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:38.942 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:12:39.259 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/artifacts.jar. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:39.386 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:39.389 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:39.432 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:39.748 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:39.801 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:39.970 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:40.005 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:40.031 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:40.188 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:12:40.339 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/content.jar. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:40.522 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:40.890 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:41.192 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:41.359 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:41.522 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:41.522 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:41.789 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:41.873 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:41.873 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:42.105 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:42.205 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:42.265 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:42.405 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:42.572 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:42.588 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:42.822 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:42.872 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:42.922 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:43.147 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:43.221 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:43.288 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:43.421 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:43.621 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:43.621 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:43.855 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:43.895 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:43.938 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:43.987 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:44.170 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:44.238 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:44.321 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:44.321 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:44.459 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:44.520 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:44.620 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:44.657 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:44.895 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:44.934 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:44.958 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:44.998 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:45.205 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:45.274 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:45.351 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:45.370 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:45.482 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:45.602 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:45.670 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:45.703 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:45.965 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:45.975 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:46.017 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:46.085 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:46.223 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:46.305 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:46.445 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:46.446 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:46.535 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:46.658 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:46.781 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:46.995 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:47.016 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:47.131 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:47.346 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:47.450 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:47.452 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:47.550 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gc-ccsRepo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:47.654 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:47.781 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:48.017 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:48.017 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:48.118 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:48.184 !MESSAGE Connection to http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:48.351 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:48.461 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:48.461 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:48.534 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:48.583 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:48.667 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:48.766 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/content.xml.xz, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:48.784 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:48.883 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:49.034 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:49.050 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:49.161 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:49.267 !MESSAGE Connection to http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/site.xml failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:49.383 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:49.483 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:49.500 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:49.649 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:49.699 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:49.733 !MESSAGE Connection to http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:49.833 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:50.061 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:50.083 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:50.166 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:50.282 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/content.xml.xz, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:50.399 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:50.482 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:50.561 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:50.715 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:50.748 !MESSAGE Connection to http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/site.xml failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:50.882 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY com.ti.ccstudio.p2app 4 0 2024-08-14 09:12:51.082 !MESSAGE The installable unit com.ti.gcc.arm.win32.feature.group has not been found. !ENTRY com.ti.ccstudio.app.center 1 0 2024-08-14 09:12:51.082 !MESSAGE Failed to install the selected add-ons. installIUs=com.ti.gcc.arm.win32.feature.group repos=http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/ !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:51.115 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:51.182 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:51.498 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:51.565 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:51.698 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:12:51.898 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:12:52.181 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:01.522 !MESSAGE Connection to https://software-dl.ti.com/ccs/non-esd/dvt/ccs6.0/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.core 4 0 2024-08-14 09:15:01.900 !MESSAGE Provisioning exception !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at https://software-dl.ti.com/ccs/non-esd/dvt/ccs6.0/content.xml. at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:249) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:69) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:89) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:126) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:110) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$1.runModal(PreloadingRepositoryHandler.java:84) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:188) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:251) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:71) ... 1 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 37 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 43 more !SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:15:01.901 !MESSAGE Unable to read repository at https://software-dl.ti.com/ccs/non-esd/dvt/ccs6.0/content.xml. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:251) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:71) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 37 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 43 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:02.264 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:02.269 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:02.580 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:02.596 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:02.810 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/content.xml.xz, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:02.904 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:03.225 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:03.313 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.core 4 0 2024-08-14 09:15:03.586 !MESSAGE Provisioning exception !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/content.jar. at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:459) at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:265) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:69) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:89) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:126) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:110) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$1.runModal(PreloadingRepositoryHandler.java:84) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:188) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) ... 1 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:15:03.586 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/content.jar. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.ui 4 0 2024-08-14 09:15:03.657 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:459) at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:265) at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.getLocalFile(CompositeMetadataRepositoryFactory.java:77) at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:100) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.p2.ui.ProvisioningUI.loadMetadataRepository(ProvisioningUI.java:498) at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getMetadataRepository(MetadataRepositoryElement.java:138) at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.fetchChildren(MetadataRepositoryElement.java:84) at org.eclipse.equinox.internal.p2.ui.model.RemoteQueriedElement.fetchDeferredChildren(RemoteQueriedElement.java:38) at org.eclipse.ui.progress.DeferredTreeContentManager$1.run(DeferredTreeContentManager.java:219) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) ... 1 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:15:03.658 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:03.761 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:03.780 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:04.086 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:04.127 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:04.326 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/content.xml.xz, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:04.329 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:04.414 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.core 4 0 2024-08-14 09:15:04.706 !MESSAGE Provisioning exception !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/content.jar. at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:459) at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:265) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:69) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:89) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:126) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:110) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$1.runModal(PreloadingRepositoryHandler.java:84) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:188) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) ... 1 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:15:04.706 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/guicomposer/v7.2/gcRepo/content.jar. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:04.747 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.ui 4 0 2024-08-14 09:15:05.092 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:459) at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:265) at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.getLocalFile(CompositeMetadataRepositoryFactory.java:77) at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:100) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.p2.ui.ProvisioningUI.loadMetadataRepository(ProvisioningUI.java:498) at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getMetadataRepository(MetadataRepositoryElement.java:138) at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getRepository(MetadataRepositoryElement.java:127) at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getQueryable(MetadataRepositoryElement.java:120) at org.eclipse.equinox.internal.p2.ui.QueryProvider.getQueryDescriptor(QueryProvider.java:93) at org.eclipse.equinox.internal.p2.ui.model.QueriedElement.fetchChildren(QueriedElement.java:104) at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.fetchChildren(MetadataRepositoryElement.java:86) at org.eclipse.equinox.internal.p2.ui.model.RemoteQueriedElement.fetchDeferredChildren(RemoteQueriedElement.java:38) at org.eclipse.ui.progress.DeferredTreeContentManager$1.run(DeferredTreeContentManager.java:219) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) ... 1 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:15:05.092 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:05.197 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:05.551 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:05.713 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/content.xml.xz, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:05.847 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:06.197 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.ui 4 0 2024-08-14 09:15:06.530 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:459) at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:265) at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.getLocalFile(CompositeMetadataRepositoryFactory.java:77) at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:100) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.p2.ui.ProvisioningUI.loadMetadataRepository(ProvisioningUI.java:498) at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getMetadataRepository(MetadataRepositoryElement.java:138) at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.fetchChildren(MetadataRepositoryElement.java:84) at org.eclipse.equinox.internal.p2.ui.model.RemoteQueriedElement.fetchDeferredChildren(RemoteQueriedElement.java:38) at org.eclipse.ui.progress.DeferredTreeContentManager$1.run(DeferredTreeContentManager.java:219) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) ... 1 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:15:06.530 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:06.657 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:07.172 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:07.374 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/content.xml.xz, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:07.476 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:07.830 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.core 4 0 2024-08-14 09:15:08.167 !MESSAGE Provisioning exception !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:459) at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:265) at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.getLocalFile(CompositeMetadataRepositoryFactory.java:77) at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:100) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:126) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:110) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$1.runModal(PreloadingRepositoryHandler.java:84) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:188) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) ... 1 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:15:08.167 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:08.213 !MESSAGE Connection to https://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:08.347 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.core 4 0 2024-08-14 09:15:08.552 !MESSAGE Provisioning exception !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at https://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/content.xml. at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:249) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:69) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:89) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:126) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:110) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$1.runModal(PreloadingRepositoryHandler.java:84) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:188) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:251) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:71) ... 1 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 37 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 43 more !SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:15:08.552 !MESSAGE Unable to read repository at https://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/codegen/Updates/p2win32/content.xml. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:251) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:71) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 37 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 43 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:08.713 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:08.893 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/content.xml.xz, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:09.004 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:09.363 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.ui 4 0 2024-08-14 09:15:09.694 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:459) at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:265) at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.getLocalFile(CompositeMetadataRepositoryFactory.java:77) at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:100) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.p2.ui.ProvisioningUI.loadMetadataRepository(ProvisioningUI.java:498) at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getMetadataRepository(MetadataRepositoryElement.java:138) at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getRepository(MetadataRepositoryElement.java:127) at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.getQueryable(MetadataRepositoryElement.java:120) at org.eclipse.equinox.internal.p2.ui.QueryProvider.getQueryDescriptor(QueryProvider.java:93) at org.eclipse.equinox.internal.p2.ui.model.QueriedElement.fetchChildren(QueriedElement.java:104) at org.eclipse.equinox.internal.p2.ui.model.MetadataRepositoryElement.fetchChildren(MetadataRepositoryElement.java:86) at org.eclipse.equinox.internal.p2.ui.model.RemoteQueriedElement.fetchDeferredChildren(RemoteQueriedElement.java:38) at org.eclipse.ui.progress.DeferredTreeContentManager$1.run(DeferredTreeContentManager.java:219) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) ... 1 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:15:09.695 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/gcc/Updates/win32/compositeContent.xml. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:09.946 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:10.280 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:11.051 !MESSAGE Connection to http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.core 4 0 2024-08-14 09:15:11.390 !MESSAGE Provisioning exception !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/content.jar. at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:459) at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:265) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:69) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:89) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:126) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:110) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$1.runModal(PreloadingRepositoryHandler.java:84) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:188) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) ... 1 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:15:11.390 !MESSAGE Unable to read repository at http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv5/Updates/content.jar. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:11.531 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:11.863 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:12.350 !MESSAGE Connection to http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.core 4 0 2024-08-14 09:15:12.699 !MESSAGE Provisioning exception !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar. at org.eclipse.equinox.internal.p2.repository.CacheManager.updateCache(CacheManager.java:459) at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:265) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:69) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:89) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:126) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:110) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$1.runModal(PreloadingRepositoryHandler.java:84) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:188) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) ... 1 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:15:12.699 !MESSAGE Unable to read repository at http://software-dl.ti.com/ccs/non-esd/eclipse_ide/v11.0/all_extras_repo/content.jar. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:12.813 !MESSAGE Connection to http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:13.144 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:13.430 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/content.xml.xz, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:13.571 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:13.947 !MESSAGE Connection to http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/site.xml failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.core 4 0 2024-08-14 09:15:14.274 !MESSAGE Provisioning exception !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/site.xml. at org.eclipse.equinox.internal.p2.updatesite.UpdateSite.loadActualSiteFile(UpdateSite.java:255) at org.eclipse.equinox.internal.p2.updatesite.UpdateSite.load(UpdateSite.java:155) at org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSiteMetadataRepositoryFactory.initializeRepository(UpdateSiteMetadataRepositoryFactory.java:108) at org.eclipse.equinox.internal.p2.updatesite.metadata.UpdateSiteMetadataRepositoryFactory.load(UpdateSiteMetadataRepositoryFactory.java:62) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:126) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:110) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$1.runModal(PreloadingRepositoryHandler.java:84) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:188) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) ... 1 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:15:14.277 !MESSAGE Unable to read repository at http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/site.xml. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:14.313 !MESSAGE Connection to https://software-dl.ti.com/ccs/esd/CCSv12/Updates/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.core 4 0 2024-08-14 09:15:14.680 !MESSAGE Provisioning exception !STACK 1 org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at https://software-dl.ti.com/ccs/esd/CCSv12/Updates/content.xml. at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache(CacheManager.java:249) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleMetadataRepositoryFactory.java:69) at org.eclipse.equinox.internal.p2.metadata.repository.SimpleMetadataRepositoryFactory.load(SimpleMetadataRepositoryFactory.java:89) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:63) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:787) at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:685) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110) at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:126) at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:110) at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$1.runModal(PreloadingRepositoryHandler.java:84) at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:188) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:251) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:71) ... 1 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 37 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 43 more !SUBENTRY 1 org.eclipse.equinox.p2.transport.ecf 4 1002 2024-08-14 09:15:14.680 !MESSAGE Unable to read repository at https://software-dl.ti.com/ccs/esd/CCSv12/Updates/content.xml. !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:251) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:71) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 37 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 43 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:32.263 !MESSAGE Connection to http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:32.597 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:32.813 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/content.xml.xz, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:32.964 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:33.362 !MESSAGE Connection to http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/site.xml failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:33.830 !MESSAGE Connection to http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/p2.index failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:34.166 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:34.390 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/content.xml.xz, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.repository 2 0 2024-08-14 09:15:34.630 !MESSAGE Using unsafe http transport to retrieve http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/, see CVE-2021-41033. Consider using https instead. !ENTRY org.eclipse.equinox.p2.transport.ecf 2 0 2024-08-14 09:15:35.021 !MESSAGE Connection to http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/site.xml failed on PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target. Retry attempt 0 started !STACK 0 javax.net.ssl.SSLHandshakeException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.ssl.Alert.createSSLException(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.TransportContext.fatal(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.checkServerCerts(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.onCertificate(Unknown Source) at java.base/sun.security.ssl.CertificateMessage$T12CertificateConsumer.consume(Unknown Source) at java.base/sun.security.ssl.SSLHandshake.consume(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.HandshakeContext.dispatch(Unknown Source) at java.base/sun.security.ssl.TransportContext.dispatch(Unknown Source) at java.base/sun.security.ssl.SSLTransport.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.decode(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at java.base/sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:273) at org.apache.hc.client5.http.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:241) at org.apache.hc.client5.http.impl.io.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:148) at org.apache.hc.client5.http.impl.io.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:396) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:158) at org.apache.hc.client5.http.impl.classic.InternalExecRuntime.connectEndpoint(InternalExecRuntime.java:168) at org.apache.hc.client5.http.impl.classic.ConnectExec.execute(ConnectExec.java:136) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ProtocolExec.execute(ProtocolExec.java:175) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.HttpRequestRetryExec.execute(HttpRequestRetryExec.java:96) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.ContentCompressionExec.execute(ContentCompressionExec.java:133) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.ExecChainElement$1.proceed(ExecChainElement.java:57) at org.apache.hc.client5.http.impl.classic.RedirectExec.execute(RedirectExec.java:115) at org.apache.hc.client5.http.impl.classic.ExecChainElement.execute(ExecChainElement.java:51) at org.apache.hc.client5.http.impl.classic.InternalHttpClient.doExecute(InternalHttpClient.java:170) at org.apache.hc.client5.http.impl.classic.CloseableHttpClient.execute(CloseableHttpClient.java:75) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.performConnect(HttpClientRetrieveFileTransfer.java:1009) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer.access$0(HttpClientRetrieveFileTransfer.java:1001) at org.eclipse.ecf.provider.filetransfer.httpclient5.HttpClientRetrieveFileTransfer$1.performFileTransfer(HttpClientRetrieveFileTransfer.java:997) at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:76) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63) Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.validator.PKIXValidator.doBuild(Unknown Source) at java.base/sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at java.base/sun.security.validator.Validator.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at java.base/sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 39 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at java.base/sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at java.base/sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.base/java.security.cert.CertPathBuilder.build(Unknown Source) ... 45 more !ENTRY com.ti.ccstudio.p2app 4 0 2024-08-14 09:15:35.365 !MESSAGE The installable unit com.ti.gcc.arm.win32.feature.group has not been found. !ENTRY com.ti.ccstudio.app.center 1 0 2024-08-14 09:15:35.367 !MESSAGE Failed to install the selected add-ons. installIUs=com.ti.gcc.arm.win32.feature.group repos=http://software-dl.ti.com/ccs/esd/gcc_arm/9.2.1/
Is there a workaround to install ARM GCC by downloading the add-on and then installing locally? I think I am unable to download anything from CCS App Center.
