TM4C129ENCPDT: Migration from Arm to GCC in TI RTOS Project getting gmake*** Error 1
Part Number: TM4C129ENCPDT
Hello everyone ,
I have recently migrating old TI RTOS based project compiled on ARM compiler to GCC compiler , I am facing gmake*** error 1,
i have built the wolfssl and TI RTOS with gcc compiler , copied the static libraries from old Arm code , i am unsuccessful in building project, please help if anyone know whonto migrate from ARM to GCC compiler.
Thanks in Advance
Chiranth Murthy
  • Hello Chiranth,
    Can you post more detail like a screenshot of the specific compilation error?
    I don't believe we have a migration guide available for ARM to GCC Compiler.
    Ralph Jacobi
  • Hi Ralph,
    Here are the  errors i am getting
    #error No or unrecognized network configuration specified
    fatal error: _lock.h: No such file or directory
    fatal error: fatfs/ff.h: No such file or directory
    gmake: *** [main.o] Error 1
    gmake: *** [modules/awsIot/mqtt.o] Error 1
    gmake: *** [modules/awsIot/platform/tirtos/network_sl.o] Error 1
    gmake: *** [modules/awsIot/src/aws_iot_jobs_interface.o] Error 1
    gmake: *** [modules/awsIot/src/aws_iot_mqtt_client_common_internal.o] Error 1
    gmake: *** [modules/awsIot/src/aws_iot_mqtt_client_connect.o] Error 1
    gmake: *** [modules/awsIot/src/aws_iot_mqtt_client_publish.o] Error 1
    gmake: *** [modules/awsIot/src/aws_iot_mqtt_client_subscribe.o] Error 1
    gmake: *** [modules/awsIot/src/aws_iot_mqtt_client_unsubscribe.o] Error 1
    gmake: *** [modules/awsIot/src/aws_iot_mqtt_client_yield.o] Error 1
    gmake: *** [modules/awsIot/src/aws_iot_mqtt_client.o] Error 1
    gmake: *** [modules/awsIot/src/aws_iot_shadow_actions.o] Error 1
    gmake: *** [modules/awsIot/src/aws_iot_shadow_records.o] Error 1
    gmake: *** [modules/awsIot/src/aws_iot_shadow.o] Error 1
    gmake: *** [modules/ cmdReceiveTask/cmdReceiver.o] Error 1
    gmake: *** [modules/httpTask/https.o] Error 1
    gmake: *** [modules/httpTask/httpsProcessor.o] Error 1
    gmake: *** [modules/obdTask/carComm.o] Error 1
    gmake: *** [modules/obdTask/obdInit.o] Error 1
    gmake: *** [modules/pmoCmds/dataRequestPmoCmd.o] Error 1
    gmake: *** [modules/pmoCmds/pmoCommands.o] Error 1
    gmake: *** [modules/serverTask/bleServer.o] Error 1
    gmake: *** [modules/utils/exit.o] Error 1
    gmake: *** [modules/utils/globalFunctions.o] Error 1
    gmake: *** [modules/utils/MX25FatFS.o] Error 1
    gmake: *** [modules/utils/test.o] Error 1
    gmake: *** [modules/utils/utility.o] Error 1
    gmake: Target 'all' not remade because of errors.
    recipe for target 'main.o' failed
    recipe for target 'modules/awsIot/mqtt.o' failed
    recipe for target 'modules/awsIot/platform/tirtos/network_sl.o' failed
    recipe for target 'modules/awsIot/src/aws_iot_jobs_interface.o' failed
    recipe for target 'modules/awsIot/src/aws_iot_mqtt_client_common_internal.o' failed
    recipe for target 'modules/awsIot/src/aws_iot_mqtt_client_connect.o' failed
    recipe for target 'modules/awsIot/src/aws_iot_mqtt_client_publish.o' failed
    recipe for target 'modules/awsIot/src/aws_iot_mqtt_client_subscribe.o' failed
    recipe for target 'modules/awsIot/src/aws_iot_mqtt_client_unsubscribe.o' failed
    recipe for target 'modules/awsIot/src/aws_iot_mqtt_client_yield.o' failed
    recipe for target 'modules/awsIot/src/aws_iot_mqtt_client.o' failed
    recipe for target 'modules/awsIot/src/aws_iot_shadow_actions.o' failed
    recipe for target 'modules/awsIot/src/aws_iot_shadow_records.o' failed
    recipe for target 'modules/awsIot/src/aws_iot_shadow.o' failed
    recipe for target 'modules/ cmdReceiveTask/cmdReceiver.o' failed
    recipe for target 'modules/httpTask/https.o' failed
    recipe for target 'modules/httpTask/httpsProcessor.o' failed
    recipe for target 'modules/obdTask/carComm.o' failed
    recipe for target 'modules/obdTask/obdInit.o' failed
    recipe for target 'modules/pmoCmds/dataRequestPmoCmd.o' failed
    recipe for target 'modules/pmoCmds/pmoCommands.o' failed
    recipe for target 'modules/serverTask/bleServer.o' failed
    recipe for target 'modules/utils/exit.o' failed
    recipe for target 'modules/utils/globalFunctions.o' failed
    recipe for target 'modules/utils/MX25FatFS.o' failed
    recipe for target 'modules/utils/test.o' failed
    recipe for target 'modules/utils/utility.o' failed
    storage size of 'tv' isn't known
    regards
    chiranth
  • Hello Chiranth,
    From what I can tell it looks like files and/or libraries were not linked correctly since the issue seems to stem from the compiler not seeing certain files. However I am not a GCC expert. You may need to look up what Error 1 means as well but I would first start by resolving the _lock.h and fatfs/ff.h errors where those files are not found.
    Ralph Jacobi
  • Hi Ralph ,
    I rectifed the error still had these errors,
    redefinition of 'g_sesSleepSecs'
    redefinition of 'g_defaultUrlPrefix'
    redefinition of 'g_defaultSw'
    redefinition of 'g_defaultHw'
    redefinition of 'g_defaultHostName'
    redefinition of 'g_defaultHistShortInterval'
    redefinition of 'g_defaultHistShipInterval'
    redefinition of 'g_defaultHistPosInterval'
    redefinition of 'g_defaultHistLongInterval'
    redefinition of 'g_commsType'
    redefinition of 'g_comms'
    redefinition of 'g_cmdSleepSecs'
    recipe for target 'modules/main.o' failed
    macro names must be identifiers
    incompatible types when initializing type 'IoT_Error_t' using type 'char *'
    gmake: *** [modules/main.o] Error 1
    expected declaration specifiers or '...' before '(' token
    conflicting types for 'SetDLData'
    conflicting types for 'pmoInit'
    conflicting types for 'getGpsLatLongMark2'
    Can you Suggest me what i am missing ?
    Thanks in advance
    Chiranth
  • Hello Chiranth,
    I am not familiar with the definitions listed so I suspect they are local files unique to your project. My guess based on the error is you have multiple files with the same definition included now. But since those are not TivaWare related I don't have any better guidance to offer.
    Ralph Jacobi
