Part Number: TMS570LS0432
Other Parts Discussed in Thread: HALCOGEN
Hi everyone,
I'm encountering a data abort exception when attempting a software reset in my project using the FreeRTOS port generated by HalCoGen.
The reset works perfectly when the RTOS isn't running, but once FreeRTOS is involved, the issue arises.
Here’s the relevant code:
/** @file sys_main.c
* @brief Application main file
* @date 11-Dec-2018
* @version 04.07.01
* This file contains an empty main function,
* which can be used for the application.
* Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* USER CODE BEGIN (0) */
/* USER CODE END */
/* Include Files */
#include "sys_common.h"
/* USER CODE BEGIN (1) */
/* USER CODE END */
/** @fn void main(void)
* @brief Application main function
* @note This function is empty by default.
* This function is called after startup.
* The user can use this function to implement the application.
/* USER CODE BEGIN (2) */
#include "FreeRTOS.h"
#include "os_task.h"
#include "gio.h"
#include "spi.h"
#include "reg_system.h"
void toggle_led();
void blinkTask(void *pvParameters);
void soft_reset();
xTaskHandle blinkTaskHandle;
/* USER CODE END */
int main(void)
/* USER CODE BEGIN (3) */
gioInit();
spiInit();
xTaskCreate(blinkTask, "Blinky", configMINIMAL_STACK_SIZE,
NULL, 1, &blinkTaskHandle);
vTaskStartScheduler();
/* USER CODE END */
return 0;
/* USER CODE BEGIN (4) */
void toggle_led(){
gioToggleBit(spiPORT2, SPI_PIN_SIMO);
gioToggleBit(spiPORT2, SPI_PIN_SOMI);
gioToggleBit(spiPORT2, SPI_PIN_CLK);
void blinkTask(void *pvParameters){
uint8_t blinky_counter = 0;
while(1){
toggle_led();
blinky_counter++;
if(blinky_counter == 6)
soft_reset();
vTaskDelay(300);
void soft_reset(){
systemREG1->SYSECR = 0x8000U;
/* USER CODE END */
Has anyone experienced this or have any insights into why the software reset fails when using FreeRTOS? Any suggestions would be greatly appreciated!
Thank you in advance!
