Part Number: AM2754-Q1
Team,
There are some E2E post below about R5F CPU access performance to OCSRAM on AM243x.
-Assuming that comparable benchmarks would be run on AM275x R5F would AM275x score better?
-By how much?
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1617634/am2434-understanding-am2434-performance/6267048
https://e2e.ti.com/support/microcontrollers/arm-based-microcontrollers-group/arm-based-microcontrollers/f/arm-based-microcontrollers-forum/1629037/am2434-am243x-vs-am261x-cpu-to-ocsram-performance-differences
Looking at the datasheets:
AM275x |
AM243x |
AM261x |
32kB cache 800Mhz or 1Ghz CPU clk |
32kB cache 800Mhz CPU clk |
16kB cache |
500Mhz clocked VBUSM 6MB OCSRAM (6x 1MB) (+ 2x 2.25MB in C7x core)
?? cycles memory latency |
250Mhz clocked VBUSM 2MB OCSRAM (8x256kB)
51 cycles memory latency (ie cycles wasted per cache misses)
200Mhz clocked VBUSM 1.5MB OCSRAM (3x512kB) (but only 2x512kB on VBUSM)
24 cycles memory latency (ie cycles wasted per cache misses) |
-What would be latency to access the OCSRAM?
-Is the AM275x interconnect comparable to the AM24x interconnect? Or are there been some improvements?
-Could you share an AM275x vs AM24x performance ratio when only using OCSRAM (no other core or peripheric used than 1x R5F and OCSRAM)?
-Do we have some app notes for the R5F perf (like AM24x perf - spracv1)?
-Or some benchmarks like in AM24x SDK 11.1 ?
Thanks in advance,
Anber
