[FAQ] AM13E23019: List of FAQs for TI AM13E230x
Part Number: AM13E23019
List of all FAQs for AM13E230x
  • Getting Started:
    Q. What are the minimum software and tools needed to start development with the AM13E230x?
    Below are the minimal requirements to get started with the evaluation and development of the device:
    1. MCU_SDK (v26.00 or higher): https://www.ti.com/tool/download/AM13E2X-SDK
    2. Sysconfig (v1.27 or higher): https://www.ti.com/tool/download/SYSCONFIG
    3. CCS (v20.5 or higher) or IAR (9.70.1 or higher): https://www.ti.com/tool/download/CCSTUDIO/20.5.0
    4. TI-ARM-CLANG compiler (v4.0.4LTS or higher): https://www.ti.com/tool/download/ARM-CGT-CLANG/4.0.4.LTS
    5. AM13E230x launchpad: https://www.ti.com/tool/LP-AM13E230
    6. Device documentation (TRM, Datasheet, User guides): https://www.ti.com/product/AM13E23019
    Q. How to import examples from the SDK and run on AM13E230x device
    Watch the below video to learn how to import examples from the MCU_SDK into CCS and run them on the target evaluation kit. If using CCS20.5 or later and the SDK version 26.00 or later, the "disable data verification" step can be skipped.
    Q. How to use mcu_sdk and AM13E230x with IAR?
    Timers
    [FAQ] AM13E230x: Issue with the sysconfig interface for timer configuration
    Boot
    [FAQ] AM13E23019: How to enable the CSC mode in AM13E230x device? How to use UART bootloader to flash image to the device?
    Resets
    [FAQ] AM13E23019: Is brownout reset supported on the AM13E230x devices and is it configurable?
    Mathlib
    [FAQ] AM13E23019: How to add FastRTS math functions to a project
    Debugger/Device connection
    [FAQ] AM13E23019: Not able to connect the AM13x device . Error connecting target error -615
    ADC
    [FAQ] AM13E23019: AM13E230x : Frequently asked ADC questions
    Matlab Embedded Coder:
    [FAQ] Embedded Coder Support Package for Texas Instruments AM13x
    Other Resources:
    AM13E230x academy: https://dev.ti.com/tirex/explore/node?node=A__AMT7zKYHtYm8t35ki.87xA__AM1X-ACADEMY__5syDipw__LATEST
