Part Number: TMS570LS1227
Hello
I'm trying to map some safety feature (taken from the Safety Manual) with the associated ESM channel (when applicable). This would help me with my testing phase and my FMEDA analysis, based on the Texas Instrument excel Spreadsheet.
Looking at the Texas Instrument Documentation about the Safety Diagnostic Library and the Datasheet, and browsing the TMS570 forum, I was able to make some associations but I'm not completely sure about the outcome. Unfortunately I couldn't find anything crystal clear in the documents.
The following section reports my guess, where each line is as follow "Unique identifier", "Safety feature" -> "ESM channel".
Please confirm my assumptions:
FLA2, Hard error cache and livelock -> raised ESM.G2.16
RAM1, Data ECC -> raised ESM.G1.26 and ESM.G1.28 in case of single (correctable) ECC error; raised ESM.G3.3 e ESM.G3.5 in case of double (uncorrectable ) ECC error
RAM2, Hard error cache and livelock -> raised ESM.G2.16
RAM6, Data/ECC storage in multiple physical banks -> raised ESM.G3.3 and ESM.G3.5. For this specific safety mechanism, shouldn't be associated also ESM.G2.6 and ESM.G2.8 ?
INC1, Error trapping (including peripheral slave error trapping) -> raised what ?
EFU2, E-fuse ECC -> raised ESM.G1.40. What about ESM.G1.41?
OTP1, OTP ECC -> raised ESM.G3.7 ?
IOM3, Error trapping -> raised ESM.G1.37?
DMA2, Non-privileged bus master access -> raised what ?
DMA4, DMA SRAM Data Parity -> raised ESM.G1.3 ?
HET6, N2HET/HTU SRAM Data Parity -> raised ESM.G1.7 for N2HET1; raised ESM.G1.34 for N2HET2; raised ESM.G1.8 for HTU1&HTU2
FRY2, Non-privileged bus master access -> raised ?
Thanks for your support,
