Part Number: TMS320F28388D
Other Parts Discussed in Thread: TMDSCNCD28388D, TMS320F28386D-Q1
Hi Team,
Good day. I am posting this inquiry on behalf of the customer.
"I have a very specific question regarding TMS320F28388DZWTS. Why, in the TMDSCNCD28388D rev B folder in the MCU063B (002) _Sch.PDF file, is the clock generated with the same pin B12 (called MCU_GPIO154) for the ethernet and EtherCAT port?
Assuming you are using EPWM5B?
Could I use respectively the ENET_RMII_CLK pin for the ethernet transceiver and the ESC_PHY_CLK for the two EtherCAT transceivers?
does the pin ENET_RMII_CLK only apply to the RMII standard or also to MII?"
Thank you for extending your help. Your support is much appreciated.
Kind regards,
Marvin
