dear team
i have used launch pad kit f280025c , during debug i have faced below issue , i could not able to flash the program in our target board . please give a solution for this .
IcePick_C_0: Error connecting to the target: (Error -2131 @ 0x0) Unable to access device register. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 9.7.0.00213) | ||||||||||||||||||||||||||
IcePick_C_0: Error connecting to the target: (Error -1265 @ 0x0) Device ID is not recognized or is not supported by driver. Confirm device and debug probe configuration is correct, or update device driver. (Emulation package 9.7.0.00213) | |||||||||||||||||||||||||
C28xx_CPU1: GEL Output: | |||||||||||||||||||||||||
RAM initialization done | |||||||||||||||||||||||||
Memory Map Initialization Complete | |||||||||||||||||||||||||
C28xx_CPU1: GEL Output: ... DCSM Initialization Start ... | |||||||||||||||||||||||||
C28xx_CPU1: GEL Output: ... DCSM Initialization Done ... | |||||||||||||||||||||||||
C28xx_CPU1: JTAG Communication Error: (Error -1135 @ 0x82F38) The debug probe reported an error. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 9.7.0.00213) | |||||||||||||||||||||||||
C28xx_CPU1: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging |
