Part Number: TMS320F2800156-Q1
Hi Aniket,
I don't think this is an issue with the flash tools. Might be a board issue. Is this with your custom board?
If not to flash, are you able to load code to RAM and execute it successfully on this board?
Thanks and regards,
Vamsi
Hi Vamsi,
Yes, We are using custom made board.
And also we tried with loading the code into RAM but still it is not happening. Also wanted to inform that the flashing has happened for the very first time, after flashing when we tried to run the code it's stuck and after terminating the stuck session it seems that the connection of controller and JTAG is not getting established.
So requesting to suggest possible causes for the same.
Aniket Chaudhary.
Hi Aniket,
Did you program anything in the DCSM OTP space? Please check your linker command file/map file and confirm.
I will loop in DCSM expert based on your reply.
Thanks and regards,
Vamsi
Hi Vamsi,
Thanks for your support. Customer confirmed that the issue is resolved by removing the GPIO configurations on J-TAG pins in program.
Sai.
