Part Number: TMS320F28035-EP
I've spend several hours trying to find out why my EPWM4 CMPA interrupt is not triggering a series of ADC conversions (SOC1,2,3,4,5. In fact, it's triggering none as witnessed by ADCINTFLG.
I can set a breakpoint at the EPWM4 interrupt, and it is firing as expected. So there must be something with either the EPWM4 configuration or SOC setups.
The goal is to trigger SOC1, SOC2, SOC3, SOC4, and SOC5 from the EPWM4 CMPA event. TBCTR is counting up. When ADCINT4 occurs (triggered by EOC3), then I will read ADCRESULT1,2,3. ADCRESULT4,5 will be read later.
EPWM4 is setup to trigger SOCA and SOCB (code below)
// Configure ePWM4 module
// We don't generate PWM with this one.
// PWM Period = 66.67uS, 15KHZ
// Count Up mode
// Set PWM output on Zero
// Clear on CMPA, CMPB compare
// TBCLK = 15MHZ (66.67nS resolution)
// CMPA triggers an ADC SOCA and SOCB event on
// first pulse.
EPwm4Regs.TBPRD = 1000; // Period = 1000 TBCLK counts (1000 x 66.67nS = 66.67uS) was 1799 GAH
EPwm4Regs.CMPA.half.CMPA = 50; // Compare A = 50 TBCLK counts
EPwm4Regs.CMPB = 50; // Compare B = 50 TBCLK counts
EPwm4Regs.TBPHS.all = 0; // Set Phase register to zero
EPwm4Regs.TBCTR = 0; // clear TB counter
EPwm4Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP;
EPwm4Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Phase loading disabled
EPwm4Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm4Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_DISABLE;
EPwm4Regs.TBCTL.bit.CLKDIV = 0; // 0 = CLKDIV = 1
EPwm4Regs.TBCTL.bit.HSPCLKDIV = 2; // 2 = HPCLKDIV = 4
// TBCLK = SYSCLKOUT / (HPCLKDIV * CLKDIV)
// TBLCK = 60MHZ / ( 4 * 1) = 15MHZ
EPwm4Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm4Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm4Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // load on CTR = Zero
EPwm4Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // load on CTR = Zero
EPwm4Regs.AQCTLA.bit.ZRO = AQ_NO_ACTION; // No action on Compare A zero
EPwm4Regs.AQCTLA.bit.CAU = AQ_NO_ACTION; // No action on Compare A match
EPwm4Regs.AQCTLB.bit.ZRO = AQ_NO_ACTION; // No action on Compare B zero
EPwm4Regs.AQCTLB.bit.CBU = AQ_NO_ACTION; // No action on Compare B match
EPwm4Regs.ETSEL.bit.SOCAEN = 1; // Enable EPWM4SOCA pulse
EPwm4Regs.ETSEL.bit.SOCBEN = 1; // Enable EPWM4SOCB pulse
EPwm4Regs.ETSEL.bit.SOCASEL = ET_CTRU_CMPA; // EPWM4SOCA pulse when TBCTR = CMPA while incrementing.
EPwm4Regs.ETSEL.bit.SOCBSEL = ET_CTRU_CMPA; // EPWM4SOCB pulse when TBCTR = CMPA while incrementing.
EPwm4Regs.ETSEL.bit.INTSEL = ET_CTRU_CMPA; // EPWM4 TBCTR = CMPA while counting up causes interrupt
EPwm4Regs.ETSEL.bit.INTEN = 0; // EPWM4INT disabled (enabled later)
EPwm4Regs.ETPS.bit.SOCAPRD = ET_1ST; // EPWM4SOCA pulse on first event
EPwm4Regs.ETPS.bit.SOCBPRD = ET_1ST; // EPWM4SOCB pulse of first event
EPwm4Regs.ETPS.bit.INTPRD = ET_1ST; // Interrupts enabled
ADC SOC setup code
// SOC1,2,3,4 and 5 are triggered by ePWM4
// CMPA event for measuring:
// SOC1 - I_MOTOR
// SOC2 - I_OFF
// SOC3 - VBUS,
// SOC4 - 3V3,
// SOC5 - TEMPERATURE (INTERNAL)
// These have the next highest priority after
// SOC0. ADC conversions will occur in
// round-robin order once triggered, starting
// at SOC1.
// SOC1
// ADCINT2
// ADCTRIG11, EPWM4, ADCSOCA
// ADCINA2, Motor Current, CH2
// Sample Window = 6 (7), 233nS
// ADCINT2 pulses generated when EOC1
// ADCINT2 enabled
// EOC1 is trigger for ADCINT2
AdcRegs.ADCSOC1CTL.bit.CHSEL = 2; // ADCINA2, I_MOT, CH2
AdcRegs.ADCSOC1CTL.bit.TRIGSEL = 11; // ADCTRIG11, ePWM4, ADCSOCA
AdcRegs.ADCSOC1CTL.bit.ACQPS = 6; // (6 + 1) x 33.33nS = 233.3 nS
AdcRegs.INTSEL1N2.bit.INT2CONT = 1; // ADCINT2 pulses generated every EOC1 event
AdcRegs.INTSEL1N2.bit.INT2E = 1; // ADCINT2 enabled
AdcRegs.INTSEL1N2.bit.INT2SEL = 1; // EOC1 is trigger for ADCINT2
// SOC2
// ADCINT3
// ADCINA1, I_OFF, CH1
// ADCINT3 pulses generated when EOC2
// ADCINT3 enabled
// EOC2 is trigger for ADCINT3
AdcRegs.ADCSOC2CTL.bit.CHSEL = 1; // ADCINA1, I_OFF, CH2
AdcRegs.ADCSOC2CTL.bit.TRIGSEL = 11; // ADCTRIG11, ePWM4, ADCSOCA
AdcRegs.ADCSOC2CTL.bit.ACQPS = 6; // (6 + 1) x 33.33nS = 233.3 nS
AdcRegs.INTSEL3N4.bit.INT3CONT = 1; // ADCINT3 pulses generated every EOC2 event
AdcRegs.INTSEL3N4.bit.INT3E = 1; // ADCINT3 enabled
AdcRegs.INTSEL3N4.bit.INT3SEL = 2; // EOC2 is trigger for ADCINT3
// SOC3
// ADCINT4
// ADCTRIG12, EPWM4, ADCSOCB
// ADCINB1, VBUS, CH9
// ADCINT4 pulses generated when EOC3
// ADCINT4 enabled
// EOC3 is trigger for ADCINT4
AdcRegs.ADCSOC3CTL.bit.CHSEL = 9; // ADCINB1, VBUS, CH9
AdcRegs.ADCSOC3CTL.bit.TRIGSEL = 12; // ADCTRIG12, ePWM4, ADCSOCB
AdcRegs.ADCSOC3CTL.bit.ACQPS = 6; // (6 + 1) x 33.33nS = 233 nSec
AdcRegs.INTSEL3N4.bit.INT4CONT = 1; // ADCINT4 pulses generated every EOC3 event
AdcRegs.INTSEL3N4.bit.INT4E = 1; // ADCINT4 enabled
AdcRegs.INTSEL3N4.bit.INT4SEL = 3; // EOC3 is trigger for ADCINT4
// SOC4
// ADCINT5
// ADCINB2, 3V3
// ADCINT5 pulses generated when EOC4
// ADCINT5 enabled
// EOC4 is trigger for ADCINT5
AdcRegs.ADCSOC4CTL.bit.CHSEL = 10; // ADCINB2, 3V3, CH10
AdcRegs.ADCSOC4CTL.bit.TRIGSEL = 12; // ADCTRIG12, ePWM4, ADCSOCB
AdcRegs.ADCSOC4CTL.bit.ACQPS = 6; // (6 + 1) x 33.33nS = 233 nSec
AdcRegs.INTSEL5N6.bit.INT5CONT = 1; // ADCINT5 pulses generated every EOC4 event
AdcRegs.INTSEL5N6.bit.INT5E = 1; // ADCINT5 enabled
AdcRegs.INTSEL5N6.bit.INT5SEL = 4; // EOC4 is trigger for ADCINT5
// SOC5
// ADCINT6
// ADCINA5 (Internal), TEMPERATURE
// ADCINT6 pulses generated when EOC5
// ADCINT6 enabled
// EOC5 is trigger for ADCINT6
AdcRegs.ADCSOC5CTL.bit.CHSEL = 5; // ADCINA5 (Internal), TEMPERATURE, CH5
AdcRegs.ADCSOC5CTL.bit.TRIGSEL = 11; // ADCTRIG11, ePWM4, ADCSOCA
AdcRegs.ADCSOC5CTL.bit.ACQPS = 6; // (6 + 1) x 33.33nS = 233 nSec
AdcRegs.INTSEL5N6.bit.INT6CONT = 1; // ADCINT6 pulses generated every EOC4 event
AdcRegs.INTSEL5N6.bit.INT6E = 1; // ADCINT6 enabled
AdcRegs.INTSEL5N6.bit.INT6SEL = 5; // EOC5 is trigger for ADCINT6
I have setup EPWM4 to generate ADCSOCA and ADCSOCB pulses since some of the channels are on ADCINA and some are on ADCINB.
Any help would be appreciated.
Additional Information
Checking the EPWM4 ETFLG register, I can see that SOCA and SOCB have been triggered, in addition to the INT flag (register value = 0x000D) This is captured with a breakpoint set at EPWM4 ISR.
But when I look at the ADCINTFLG register (value = 0x0000) is see that no conversions have been completed.
Now you might say that no conversions have had time to complete yet, so no flags will be set (yet). But if I continue to single set out of the interrupt, and continue to step for a long time afterward, no ADCINTFLG ever gets set.
It appears, that at least for EPWM4, that the SOCA and SOCB flags are not triggering ADC conversions.
Also, here is the rest of the ADC initialization code.
You can see that SOCPRIORITY = 1, which sets SOC0 as highest priority, and SOC1-15 are in round robin mode.
// ADC Configuration
// ADC external reference
// Reference buffers on
// ADC Powered Up
// ADC Enabled
// BandGap circuit powered on
// ADC result latched 1 cycle prior to result
// VREFLO internally connected to ADC for sampling
// Temperature sensor connected internally to ADCINA5
AdcRegs.ADCCTL1.bit.ADCREFSEL = 1; // ADC External references
AdcRegs.ADCCTL1.bit.ADCPWDN = 1; // ADC power on
AdcRegs.ADCCTL1.bit.ADCREFPWD = 1; // reference buffer on
AdcRegs.ADCCTL1.bit.ADCBGPWD = 1; // band-gap powered on (MUST BE ON FOR ADC TO WORK)
AdcRegs.ADCCTL1.bit.ADCENABLE = 1; // ADC Enabled
AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1; // INT pulse 1 cycle before ADC result latched
AdcRegs.ADCCTL1.bit.VREFLOCONV = 1; // VREFLO connected internally to ADC
AdcRegs.ADCCTL1.bit.TEMPCONV = 1; // temperature sensor connected to ADCINA5 internally
AdcRegs.SOCPRICTL.bit.SOCPRIORITY = 1; // SOC0 highest, SOC1-15 round robin
// No overlap of sample and conversion
// ADCCLK = SYSCLK/2 (30MHZ)
AdcRegs.ADCCTL2.bit.ADCNONOVERLAP = 1; // No overlap of sample and conversion
AdcRegs.ADCCTL2.bit.CLKDIV2EN = 1; // ADCCLK = 30MHZ
Any comments ?
