Other Parts Discussed in Thread: CONTROLSUITE
Hi all.
I'm trying to make some experimental tests with TMDSHVRESLLCKIT. My first goal is to verify, that my whole development environment works as it should. When I'm loading program to F28027, an error message appears: C28xx: File Loader: Data verification failed at address 0x003F7078 Please verify target memory and memory map.
Apparently debuggers memory map and linker command file are not supporting each other? At this point I don't have enough skills to make appropriate modifications to *.gel file, so could someone help me with this issue.
FYI, all files are copied from example project file of Control Suite.
Thanks.
