Hello everyone,
I am using the emulator, eZdspTMF28335 and code composer v6 to compile. It was working fine yesterday when I tried to use jtag to dl program and got this error.
C28xx: Flash Programmer: Warning: The configured device (TMS320F28335), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: Failed CPU Reset: Error 0x20000024/-1137 Severe Error during: Register, Execution, It appears that the target is being held in reset. This may be due to Wait-In-Reset (WIR) configuration set by the EMU 0/1 pin settings. If this is the case, press Cancel and disconnect all connected devices to attempt to clear the WIR configuration. If this is a multi-core system, the master CPU or ICEPick may not be releasing the target from reset. Please check your configuration and/or your GEL files to ensure that nothing is blocking the target from being released from reset.
C28xx: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
I disconnect the jtag and tried again but the module seems like held in reset and not starting.
Did the processor get fried? Any help would be appreciated . Thank You very much.
