Part Number: TMS320F28027F
Other Parts Discussed in Thread: TMS320F28027, MOTORWARE, C2000WARE
I have a custom F28027 board. I have 2 identical boards. 1 board is fine and gets connected to debug session, in other board i am getting following error message during debug connection.
C28xx: GEL Output:
Device Calibration not complete, check if device is unlocked and recalibrate.C28xx: Flash Programmer: Warning: The configured device (TMS320F28027), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: Failed CPU Reset: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 7.0.188.0)
C28xx: Trouble Reading Register PC: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 7.0.188.0)
C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 7.0.188.0)
C28xx: GEL: Error while executing OnReset(1): Target failed to read register ST1
at (ST1&~(0x0100)) [f28027.gel:283]
at C28x_Mode() [f28027.gel:33]
at OnReset(1)
C28xx: Trouble Writing Memory Block at 0xae0 on Page 1 of Length 0x1: (Error -1137 @ 0xAE1) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 7.0.188.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE0@Data
C28xx: Trouble Writing Memory Block at 0xae1 on Page 1 of Length 0x1: (Error -1137 @ 0xAE2) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 7.0.188.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE1@Data
C28xx: Trouble Writing Memory Block at 0xae2 on Page 1 of Length 0x1: (Error -1137 @ 0xAE3) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 7.0.188.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE2@Data
C28xx: Trouble Writing Memory Block at 0xae3 on Page 1 of Length 0x1: (Error -1137 @ 0xAE4) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 7.0.188.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE3@Data
C28xx: Trouble Writing Memory Block at 0xae4 on Page 1 of Length 0x1: (Error -1137 @ 0xAE5) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 7.0.188.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE4@Data
C28xx: Trouble Writing Memory Block at 0xae5 on Page 1 of Length 0x1: (Error -1137 @ 0xAE6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 7.0.188.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE5@Data
C28xx: Trouble Writing Memory Block at 0xae6 on Page 1 of Length 0x1: (Error -1137 @ 0xAE7) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 7.0.188.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE6@Data
C28xx: Trouble Writing Memory Block at 0xae7 on Page 1 of Length 0x1: (Error -1137 @ 0xAE8) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 7.0.188.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE7@Data
C28xx: Flash Programmer: Device is locked or not connected. Operation cancelled.
C28xx: File Loader: Memory write failed: Unknown error
C28xx: GEL: File: C:\Users\Pallavi Joshi\Google Drive\BLDC-FOC\CCS_Instapsin\motorware_Torque_V1_2\sw\solutions\instaspin_foc\boards\Torque_V1_2\f28x\f2802xF\projects\ccs\proj_lab05b\Flash\proj_lab05b.out: Load failed.
I have checked status of XRSn pin, though it is pulled up with 2.2k, it shows 0.1V.
When I test JTAG connection it succeeds.
To rule our possibility of broken controller, I tested controller to another board and it works just fine.
Since the first board is working fine i suspect this to be a soldering/component issue, but I still want to know what is the reason for this problem.
Shubham
