TMS320F28379D: I'm trying to figure out how to change the linker file to acquire more memory
Part Number: TMS320F28379D
I'm using simulink to interface with the TI board i want to change the linker file in order to combine my memory to acquire more memory since its saying my program is to big i will upload all the files.
here my linker command file
#ifdef CLA_BLOCK_INCLUDED
// Define a size for the CLA scratchpad area that will be used
// by the CLA compiler for local symbols and temps
// Also force references to the special symbols that mark the
// scratchpad are.
CLA_SCRATCHPAD_SIZE = 0x100;
--undef_sym=__cla_scratchpad_end
--undef_sym=__cla_scratchpad_start
#endif //CLA_BLOCK_INCLUDED
MEMORY
PAGE 0 :
/* BEGIN is used for the "boot to SARAM" bootloader mode */
BEGIN : origin = 0x000000, length = 0x000002
BEGIN_FLASH : origin = 0x080000, length = 0x000002
#ifdef CPU1
RAMM0 : origin = 0x000122, length = 0x0002DE
#else
RAMM0 : origin = 0x000080, length = 0x000380
#endif
RAMD0 : origin = 0x00B000, length = 0x000800
RAMLS_PROG : origin = 0x00A000, length = 0x000800
RAMLS_CLA_PROG : origin = 0x00A800, length = 0x000800
#else
RAMLS_PROG : origin = 0x009000, length = 0x002000
#ifdef CPU1
#if BOOT_FROM_FLASH
RAMGS_PROG : origin = 0x017000, length = 0x001000
#else
RAMGS_PROG : origin = 0x014000, length = 0x004000
#endif
#endif
RESET : origin = 0x3FFFC0, length = 0x000002
/* Flash sectors */
FLASHA_N : origin = 0x080002, length = 0x03FFFE /* on-chip Flash */
PAGE 1 :
#ifdef CPU1
BOOT_RSVD : origin = 0x000002, length = 0x000120 /* Part of M0, BOOT rom will use this for stack */
#else
BOOT_RSVD : origin = 0x000002, length = 0x00007E /* Part of M0, BOOT rom will use this for stack */
#endif
RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */
RAMD1 : origin = 0x00B800, length = 0x000800
RAMLS_CLA_DATA : origin = 0x008000, length = 0x001000
RAMLS_DATA : origin = 0x009000, length = 0x001000
#else
RAMLS_DATA : origin = 0x008000, length = 0x001000
#ifdef CPU1
#if BOOT_FROM_FLASH
RAMGS_DATA : origin = 0x00E000, length = 0x00B000
#else
RAMGS_DATA : origin = 0x00E000, length = 0x008000
#endif
#endif
RAMGS_IPCBuffCPU1 : origin = 0x00C000, length = 0x001000
RAMGS_IPCBuffCPU2 : origin = 0x00D000, length = 0x001000
CLA1_MSGRAMLOW : origin = 0x001480, length = 0x000080
CLA1_MSGRAMHIGH : origin = 0x001500, length = 0x000080
CPU2TOCPU1RAM : origin = 0x03F800, length = 0x000400
CPU1TOCPU2RAM : origin = 0x03FC00, length = 0x000400
SECTIONS
#if BOOT_FROM_FLASH
/* Allocate program areas: */
.cinit : > FLASHA_N PAGE = 0, ALIGN(4)
.pinit : > FLASHA_N, PAGE = 0, ALIGN(4)
.text : > FLASHA_N PAGE = 0, ALIGN(4)
codestart : > BEGIN_FLASH PAGE = 0, ALIGN(4)
ramfuncs : LOAD = FLASHA_N,
RUN = RAMLS_PROG,
LOAD_START(_RamfuncsLoadStart),
LOAD_SIZE(_RamfuncsLoadSize),
LOAD_END(_RamfuncsLoadEnd),
RUN_START(_RamfuncsRunStart),
RUN_SIZE(_RamfuncsRunSize),
RUN_END(_RamfuncsRunEnd),
PAGE = 0, ALIGN(4)
/* Initalized sections go in Flash */
.econst : > FLASHA_N PAGE = 0, ALIGN(4)
.switch : > FLASHA_N PAGE = 0, ALIGN(4)
/* Allocate IQmath areas: */
IQmath : > FLASHA_N, PAGE = 0, ALIGN(4) /* Math Code */
IQmathTables : > FLASHA_N, PAGE = 0, ALIGN(4)
/* CLA specific sections */
Cla1Prog : LOAD = FLASHA_N,
RUN = RAMLS_CLA_PROG,
LOAD_START(_Cla1funcsLoadStart),
LOAD_END(_Cla1funcsLoadEnd),
RUN_START(_Cla1funcsRunStart),
LOAD_SIZE(_Cla1funcsLoadSize),
PAGE = 0, ALIGN(4)
#else
codestart : > BEGIN, PAGE = 0
ramfuncs : > RAMM0 PAGE = 0
#ifdef CPU1
.text : >>RAMM0 | RAMD0 | RAMLS_PROG | RAMGS_PROG, PAGE = 0
#else
.text : >>RAMM0 | RAMD0 | RAMLS_PROG, PAGE = 0
#endif
.cinit : > RAMM0 | RAMD0 | RAMLS_PROG | RAMGS_PROG, PAGE = 0
.pinit : > RAMM0, PAGE = 0
.switch : > RAMM0, PAGE = 0
.econst : > RAMLS_DATA, PAGE = 1
/* Allocate IQ math areas: */
IQmath : > RAMLS_PROG, PAGE = 0 /* Math Code */
IQmathTables : > RAMLS_PROG, PAGE = 0
Cla1Prog : > RAMLS_CLA_PROG, PAGE=0
#endif
.stack : > RAMM1, PAGE = 1
#ifdef CPU1
.ebss : >> RAMLS_DATA| RAMD1 | RAMGS_DATA , PAGE = 1
#else
.ebss : >> RAMLS_DATA| RAMD1, PAGE = 1
#endif
.reset : > RESET, PAGE = 0, TYPE = DSECT /* not used, */
.esysmem : > RAMLS_DATA, PAGE = 1
/* CLA C compiler sections */
// Must be allocated to memory the CLA has write access to
Cla1DataRam0 : > RAMLS_CLA_DATA, PAGE=1
Cla1ToCpuMsgRAM : > CLA1_MSGRAMLOW, PAGE = 1
CpuToCla1MsgRAM : > CLA1_MSGRAMHIGH, PAGE = 1
CLAscratch :
{ *.obj(CLAscratch)
. += CLA_SCRATCHPAD_SIZE;
*.obj(CLAscratch_end) } > RAMLS_CLA_DATA, PAGE = 1
.scratchpad : > RAMLS_CLA_DATA, PAGE = 1
.bss_cla : > RAMLS_CLA_DATA, PAGE = 1
.const_cla : LOAD = FLASHA_N,
RUN = RAMLS_CLA_DATA,
RUN_START(_Cla1ConstRunStart),
LOAD_START(_Cla1ConstLoadStart),
LOAD_SIZE(_Cla1ConstLoadSize),
PAGE = 1
#ifdef CPU1
/* The following section definitions are required when using the IPC API Drivers */
GROUP : > CPU1TOCPU2RAM, PAGE = 1
PUTBUFFER
PUTWRITEIDX
GETREADIDX
WRITEFLAG1CPU1
WRITEFLAG2CPU1
READFLAG1CPU1
READFLAG2CPU1
GROUP : > CPU2TOCPU1RAM, PAGE = 1
GETBUFFER : TYPE = DSECT
GETWRITEIDX : TYPE = DSECT
PUTREADIDX : TYPE = DSECT
WRITEFLAG1CPU2: TYPE = DSECT
WRITEFLAG2CPU2: TYPE = DSECT
READFLAG1CPU2: TYPE = DSECT
READFLAG2CPU2: TYPE = DSECT
#else
PUTBUFFER
PUTWRITEIDX
GETREADIDX
WRITEFLAG1CPU2
WRITEFLAG2CPU2
READFLAG1CPU2
READFLAG2CPU2
WRITEFLAG1CPU1: TYPE = DSECT
WRITEFLAG2CPU1: TYPE = DSECT
READFLAG1CPU1 : TYPE = DSECT
READFLAG2CPU1 : TYPE = DSECT
#endif
GROUP : > RAMGS_IPCBuffCPU1, PAGE = 1
CPU1TOCPU2GSRAM
GROUP : > RAMGS_IPCBuffCPU2, PAGE = 1
CPU2TOCPU1GSRAM
// End of file.
  • Hi Sam,
    For which section did you face issue? Can you please provide the error message you got on the console?
    Sudharsanan
  • "C:/ProgramData/MATLAB/SupportPackages/R2018a/toolbox/target/supportpackages/tic2000/src/c28377D.cmd", line 129: error:
    program will not fit into available memory. run placement with
    alignment/blocking fails for section ".ebss" size 0x244b4 page 1. Available
    memory ranges:
    RAMLS_DATA size: 0x1000 unused: 0xfc3 max hole: 0xfc3
    RAMD1 size: 0x800 unused: 0x800 max hole: 0x800
    RAMGS_DATA size: 0xb000 unused: 0xb000 max hole: 0xb000
    error: errors encountered during linking; "../singal_testing.out" not built
    >> Compilation failure
    gmake: *** [../singal_testing.out] Error 1
    C:\Users\ctyoung43\Documents\MATLAB\Final Model\singal_testing_ert_rtw>echo The make command returned an error of 2
    C:\Users\ctyoung43\Documents\MATLAB\Final Model\singal_testing_ert_rtw>An_error_occurred_during_the_call_to_make
    'An_error_occurred_during_the_call_to_make' is not recognized as an internal or external command,
    operable program or batch file.
    ### Creating HTML report file singal_testing_codegen_rpt.html
    ### Build procedure for model: 'singal_testing' aborted due to an error.
    Error(s) encountered while building "singal_testing":
    ### Failed to generate all binary outputs.
  • Hi Sam,
    Glad to know that you got issue resolved.
    Sudharsanan
  • I wasn't able to test it yet we only have one licenses of embedded coder on campus and someone had it checked out the whole weekend.
  • How do i modify the linker file to make these unused memory space be used.
  • Like in my linker file how do i combine those three. Like this? RAMLS_DATA_D1_GS_DATA
  • Sam,
    You can combine contiguous memories in linker command files. Have a common origin: and then add up the length to get a combined space.
    software-dl.ti.com/.../sdto_cgt_Linker-Command-File-Primer.html
    Sudharsanan
