Part Number: TMS320F28335
The following link "http://www.ti.com/lit/an/spraaj2/spraaj2.pdf"
Somehow only a small part of my question was posted and the rest of it are missing. I know that this particular link is working, the problem is that there are links inside this pdf that are supposed to link to the source codes or manuals but they do not work.The image above shows that the link that I need for the source codes (Triple w)-s.ti.com/sc/techlit/spraaj2.zip does not work.I changed the "www" to "(Triple w)" because I wanted to show the url here instead of it autolinking to the web page that can't be found. Basically all the links provided in this and a few other documents that I found do not work.
Those links are working for me. I see one or two links on the last page (notice) which are broken, but that's because the product shortcuts have changed since the application note was written in 2008. All the document links on p.2 are working.
I have attached the .zip file in case you need it. Let me know if there is something specific you need and I will find a way to get you that.
Can you check there isn't a fire-wall or virus checker blocking downloads?
Richard
Thanks for your help. Although I'm still unable to access those links, a friend has provided me with the documents I need.
