Part Number: TMS320F28027
I am having trouble changing the phase between ePWM 1 and ePWM 2 using HRPWM. I have set the TBPHSHR register to 58 by doing EPwm2Regs.TBPHS.half.TBPHSHR = (58 << 8); and TBPRD register to EPwm2Regs.TBPRD = 86 to see a phase shift of 120 degrees. Is this the correct way to set TBPHSHR? Below is my code with the initializations for EPWM 1 and 2.
void
InitEPwm1Example()
EPwm1Regs.TBPRD = EPWM1_TIMER_TBPRD; // Period = 900 TBCLK counts
//EPwm1Regs.TBPHS.half.TBPHS = 0; // Set Phase register to zero (Commented out since I want to use High Resolution)
EPwm1Regs.TBPHS.half.TBPHSHR = 0; // Set Phase register to zero
EPwm1Regs.TBCTR = 0x0000; // Clear counter
EPwm1Regs.CMPA.half.CMPA = EPWM1_MIN_CMPA; // Set compare A value
EPwm1Regs.CMPB = EPWM1_MIN_CMPB; // Set Compare B value
// was not here prior to 3/31
EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT -- > TBCLK = SYSCLKOUT = 60 MHz
EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Symmetrical mode
EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Master module
EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO; // Sync down-stream module
EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // load on CTR=Zero
EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // load on CTR=Zero
EPwm1Regs.AQCTLA.bit.CAU = AQ_SET; // set actions for EPWM1A
EPwm1Regs.AQCTLA.bit.CAD = AQ_CLEAR;
EPwm1Regs.AQCTLB.bit.CBU = AQ_SET; // Set PWM1B on event B, up count
EPwm1Regs.AQCTLB.bit.CBD = AQ_CLEAR; // Clear PWM1B on event B, down count
// HRPWM Code
EALLOW; // Note these registers are protected
EPwm1Regs.HRCNFG.all = 0x0; // clear all bits first
EPwm1Regs.HRCNFG.bit.AUTOCONV = 1; // Enable autoconversion for HR period
EPwm1Regs.HRPCTL.bit.TBPHSHRLOADE = 1; // This bit allows you to synchronize ePWM modules with a high-resolution phase on a SYNCIN, TBCTL[SWFSYNC] or digital compare event
EPwm1Regs.HRCNFG.bit.HRLOAD = HR_CTR_ZERO; // Shadow load on CTR=Zero
EPwm1Regs.HRCNFG.bit.EDGMODE = HR_BEP; // Control Both Edge Position
EPwm1Regs.HRCNFG.bit.CTLMODE = HR_PHS; // PHSHR controls the MEP
EDIS;
// InitEPwm2Example -
void
InitEPwm2Example()
EPwm2Regs.TBPRD = EPWM2_TIMER_TBPRD; // Period = 900 TBCLK counts
//EPwm2Regs.TBPHS.half.TBPHS = 58; // Set Phase register to zero (Commented out since I want to use High Resolution)
EPwm2Regs.TBPHS.half.TBPHSHR = (58 << 8); // Set Phase register to zero
EPwm2Regs.TBCTR = 0x0000; // Clear counter
EPwm2Regs.CMPA.half.CMPA = EPWM2_MIN_CMPA; // Set compare A value
EPwm2Regs.CMPB = EPWM2_MIN_CMPB; // Set Compare B value
EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT -- > TBCLK = SYSCLKOUT = 60 MHz
EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Symmetrical mode
EPwm2Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Master module
EPwm2Regs.TBCTL.bit.PHSDIR = TB_DOWN; // Count DOWN on sync (=120 deg)
EPwm2Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // Sync down-stream module
EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW;
EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // load on CTR=Zero
EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // load on CTR=Zero
EPwm2Regs.AQCTLA.bit.CAU = AQ_SET; // set actions for EPWM1A
EPwm2Regs.AQCTLA.bit.CAD = AQ_CLEAR;
EPwm2Regs.AQCTLB.bit.CBU = AQ_SET; // Set PWM1B on event B, up count
EPwm2Regs.AQCTLB.bit.CBD = AQ_CLEAR; // Clear PWM1B on event B, down count
// HRPWM Code
EPwm2Regs.HRCNFG.all = 0x0; // clear all bits first
EPwm2Regs.HRCNFG.bit.AUTOCONV = 1; // Enable autoconversion for HR period
EPwm2Regs.HRPCTL.bit.TBPHSHRLOADE = 1; // This bit allows you to synchronize ePWM modules with a high-resolution phase on a SYNCIN, TBCTL[SWFSYNC] or digital compare event
EPwm2Regs.HRCNFG.bit.HRLOAD = HR_CTR_ZERO; // Shadow load on CTR=Zero
EPwm2Regs.HRCNFG.bit.EDGMODE = HR_BEP; // Control Both Edge Position
EPwm2Regs.HRCNFG.bit.CTLMODE = HR_PHS; // PHSHR controls the MEP
EDIS;
