I have a problem compiling my project for a MSP430FR5739. The code is large, and relies on size-optimisation and compression to fit into the FRAM - which it did just fine, until possibly a full rebuild was necessary. Recently, I have been getting the following warning again:
"warning #10229-D: output section ".data" refers to load symbol "_nop" and hence cannot be compressed; compression "lzss" is ignored" followed by a out of memory error.
""../lnk_msp430fr5739.cmd", line 132: error #10099-D: program will not fit into available memory, or the section contains a call site that requires a trampoline that can't be generated for this section. placement with alignment fails for section "ALL_FRAM" size 0x41b9. Available memory ranges:"
I'm using CCS v10.4, and compiler version TI v20.2.5.LTS.
This issue appeared before, and I somehow had managed to fix it - but I can't quite remember how. I've been following advice in https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/561407/compiler-msp430f5310-10229-d-output-section-data-refers-to-load-symbol-_nop-and-hence-cannot-be-compressed-ccs-6-2-msp430f5310-compiler-16-9-1 and https://e2e.ti.com/support/tools/code-composer-studio-group/ccs/f/code-composer-studio-forum/86954/arm-4-6-4-linker-warning to no avail.
Wherever I move .cinit in the linker command file, I get the same error. I also can't point to a possible circular dependency in my code.
I'd be happy to share the project with TI, but not publicly. I've attached the linker command file.
Are there any other tricks to try?
Kai
*edit* here's the linker command file, as the upload didn't seem to have worked.
/* ============================================================================ */ /* Copyright (c) 2020, Texas Instruments Incorporated */ /* All rights reserved. */ /* */ /* Redistribution and use in source and binary forms, with or without */ /* modification, are permitted provided that the following conditions */ /* are met: */ /* */ /* * Redistributions of source code must retain the above copyright */ /* notice, this list of conditions and the following disclaimer. */ /* */ /* * Redistributions in binary form must reproduce the above copyright */ /* notice, this list of conditions and the following disclaimer in the */ /* documentation and/or other materials provided with the distribution. */ /* */ /* * Neither the name of Texas Instruments Incorporated nor the names of */ /* its contributors may be used to endorse or promote products derived */ /* from this software without specific prior written permission. */ /* */ /* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" */ /* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, */ /* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR */ /* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR */ /* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, */ /* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, */ /* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; */ /* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, */ /* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR */ /* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */ /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* ============================================================================ */ /******************************************************************************/ /* lnk_msp430fr5739.cmd - LINKER COMMAND FILE FOR LINKING MSP430FR5739 PROGRAMS */ /* */ /* Usage: lnk430 <obj files...> -o <out file> -m <map file> lnk.cmd */ /* cl430 <src files...> -z -o <out file> -m <map file> lnk.cmd */ /* */ /*----------------------------------------------------------------------------*/ /* These linker options are for command line linking only. For IDE linking, */ /* you should set your linker options in Project Properties */ /* -c LINK USING C CONVENTIONS */ /* -stack 0x0100 SOFTWARE STACK SIZE */ /* -heap 0x0100 HEAP AREA SIZE */ /* */ /*----------------------------------------------------------------------------*/ /* Version: 1.211 */ /*----------------------------------------------------------------------------*/ /****************************************************************************/ /* Specify the system memory map */ /****************************************************************************/ MEMORY { SFR : origin = 0x0000, length = 0x0010 PERIPHERALS_8BIT : origin = 0x0010, length = 0x00F0 PERIPHERALS_16BIT : origin = 0x0100, length = 0x0100 RAM : origin = 0x1C00, length = 0x0400 INFOA : origin = 0x1880, length = 0x0080 INFOB : origin = 0x1800, length = 0x0080 FRAM : origin = 0xC200, length = 0x3D80 JTAGSIGNATURE : origin = 0xFF80, length = 0x0004, fill = 0xFFFF BSLSIGNATURE : origin = 0xFF84, length = 0x0004, fill = 0xFFFF IPESIGNATURE : origin = 0xFF88, length = 0x0008, fill = 0xFFFF INT00 : origin = 0xFF90, length = 0x0002 INT01 : origin = 0xFF92, length = 0x0002 INT02 : origin = 0xFF94, length = 0x0002 INT03 : origin = 0xFF96, length = 0x0002 INT04 : origin = 0xFF98, length = 0x0002 INT05 : origin = 0xFF9A, length = 0x0002 INT06 : origin = 0xFF9C, length = 0x0002 INT07 : origin = 0xFF9E, length = 0x0002 INT08 : origin = 0xFFA0, length = 0x0002 INT09 : origin = 0xFFA2, length = 0x0002 INT10 : origin = 0xFFA4, length = 0x0002 INT11 : origin = 0xFFA6, length = 0x0002 INT12 : origin = 0xFFA8, length = 0x0002 INT13 : origin = 0xFFAA, length = 0x0002 INT14 : origin = 0xFFAC, length = 0x0002 INT15 : origin = 0xFFAE, length = 0x0002 INT16 : origin = 0xFFB0, length = 0x0002 INT17 : origin = 0xFFB2, length = 0x0002 INT18 : origin = 0xFFB4, length = 0x0002 INT19 : origin = 0xFFB6, length = 0x0002 INT20 : origin = 0xFFB8, length = 0x0002 INT21 : origin = 0xFFBA, length = 0x0002 INT22 : origin = 0xFFBC, length = 0x0002 INT23 : origin = 0xFFBE, length = 0x0002 INT24 : origin = 0xFFC0, length = 0x0002 INT25 : origin = 0xFFC2, length = 0x0002 INT26 : origin = 0xFFC4, length = 0x0002 INT27 : origin = 0xFFC6, length = 0x0002 INT28 : origin = 0xFFC8, length = 0x0002 INT29 : origin = 0xFFCA, length = 0x0002 INT30 : origin = 0xFFCC, length = 0x0002 INT31 : origin = 0xFFCE, length = 0x0002 INT32 : origin = 0xFFD0, length = 0x0002 INT33 : origin = 0xFFD2, length = 0x0002 INT34 : origin = 0xFFD4, length = 0x0002 INT35 : origin = 0xFFD6, length = 0x0002 INT36 : origin = 0xFFD8, length = 0x0002 INT37 : origin = 0xFFDA, length = 0x0002 INT38 : origin = 0xFFDC, length = 0x0002 INT39 : origin = 0xFFDE, length = 0x0002 INT40 : origin = 0xFFE0, length = 0x0002 INT41 : origin = 0xFFE2, length = 0x0002 INT42 : origin = 0xFFE4, length = 0x0002 INT43 : origin = 0xFFE6, length = 0x0002 INT44 : origin = 0xFFE8, length = 0x0002 INT45 : origin = 0xFFEA, length = 0x0002 INT46 : origin = 0xFFEC, length = 0x0002 INT47 : origin = 0xFFEE, length = 0x0002 INT48 : origin = 0xFFF0, length = 0x0002 INT49 : origin = 0xFFF2, length = 0x0002 INT50 : origin = 0xFFF4, length = 0x0002 INT51 : origin = 0xFFF6, length = 0x0002 INT52 : origin = 0xFFF8, length = 0x0002 INT53 : origin = 0xFFFA, length = 0x0002 INT54 : origin = 0xFFFC, length = 0x0002 RESET : origin = 0xFFFE, length = 0x0002 } /****************************************************************************/ /* Specify the sections allocation into memory */ /****************************************************************************/ SECTIONS { //.cinit : {} GROUP(ALL_FRAM) { GROUP(READ_WRITE_MEMORY) { .TI.persistent : {} /* For #pragma persistent */ .cio : {} /* C I/O buffer */ .sysmem : {} /* Dynamic memory allocation area */ } ALIGN(0x0200), RUN_START(fram_rw_start) // .cinit : {} GROUP(READ_ONLY_MEMORY) { .cinit : {} /* Initialization tables */ .pinit : {} /* C++ constructor tables */ .binit : {} /* Boot-time Initialization tables */ .init_array : {} /* C++ constructor tables */ .mspabi.exidx : {} /* C++ constructor tables */ .mspabi.extab : {} /* C++ constructor tables */ .const : {} /* Constant data */ } ALIGN(0x0200), RUN_START(fram_ro_start) GROUP(EXECUTABLE_MEMORY) { .text : {} /* Code */ } ALIGN(0x0200), RUN_START(fram_rx_start) } > FRAM #ifdef __TI_COMPILER_VERSION__ #if __TI_COMPILER_VERSION__ >= 15009000 #ifndef __LARGE_CODE_MODEL__ .TI.ramfunc : {} load=FRAM, run=RAM, table(BINIT) #else .TI.ramfunc : {} load=FRAM | FRAM2, run=RAM, table(BINIT) #endif #endif #endif .jtagsignature : {} > JTAGSIGNATURE /* JTAG Signature */ .bslsignature : {} > BSLSIGNATURE /* BSL Signature */ GROUP(SIGNATURE_SHAREDMEMORY) { .ipesignature : {} /* IPE Signature */ .jtagpassword : {} /* JTAG Password */ } > IPESIGNATURE .bss : {} > RAM /* Global & static vars */ .data : {} > RAM /* Global & static vars */ .TI.noinit : {} > RAM /* For #pragma noinit */ .stack : {} > RAM (HIGH) /* Software system stack */ .infoA (NOLOAD) : {} > INFOA /* MSP430 INFO FRAM Memory segments */ .infoB (NOLOAD) : {} > INFOB /* MSP430 Interrupt vectors */ .int00 : {} > INT00 .int01 : {} > INT01 .int02 : {} > INT02 .int03 : {} > INT03 .int04 : {} > INT04 .int05 : {} > INT05 .int06 : {} > INT06 .int07 : {} > INT07 .int08 : {} > INT08 .int09 : {} > INT09 .int10 : {} > INT10 .int11 : {} > INT11 .int12 : {} > INT12 .int13 : {} > INT13 .int14 : {} > INT14 .int15 : {} > INT15 .int16 : {} > INT16 .int17 : {} > INT17 .int18 : {} > INT18 .int19 : {} > INT19 .int20 : {} > INT20 .int21 : {} > INT21 .int22 : {} > INT22 .int23 : {} > INT23 .int24 : {} > INT24 .int25 : {} > INT25 .int26 : {} > INT26 .int27 : {} > INT27 .int28 : {} > INT28 .int29 : {} > INT29 .int30 : {} > INT30 RTC : { * ( .int31 ) } > INT31 type = VECT_INIT PORT4 : { * ( .int32 ) } > INT32 type = VECT_INIT PORT3 : { * ( .int33 ) } > INT33 type = VECT_INIT TIMER2_B1 : { * ( .int34 ) } > INT34 type = VECT_INIT TIMER2_B0 : { * ( .int35 ) } > INT35 type = VECT_INIT PORT2 : { * ( .int36 ) } > INT36 type = VECT_INIT TIMER1_B1 : { * ( .int37 ) } > INT37 type = VECT_INIT TIMER1_B0 : { * ( .int38 ) } > INT38 type = VECT_INIT PORT1 : { * ( .int39 ) } > INT39 type = VECT_INIT TIMER1_A1 : { * ( .int40 ) } > INT40 type = VECT_INIT TIMER1_A0 : { * ( .int41 ) } > INT41 type = VECT_INIT DMA : { * ( .int42 ) } > INT42 type = VECT_INIT USCI_A1 : { * ( .int43 ) } > INT43 type = VECT_INIT TIMER0_A1 : { * ( .int44 ) } > INT44 type = VECT_INIT TIMER0_A0 : { * ( .int45 ) } > INT45 type = VECT_INIT ADC10 : { * ( .int46 ) } > INT46 type = VECT_INIT USCI_B0 : { * ( .int47 ) } > INT47 type = VECT_INIT USCI_A0 : { * ( .int48 ) } > INT48 type = VECT_INIT WDT : { * ( .int49 ) } > INT49 type = VECT_INIT TIMER0_B1 : { * ( .int50 ) } > INT50 type = VECT_INIT TIMER0_B0 : { * ( .int51 ) } > INT51 type = VECT_INIT COMP_D : { * ( .int52 ) } > INT52 type = VECT_INIT UNMI : { * ( .int53 ) } > INT53 type = VECT_INIT SYSNMI : { * ( .int54 ) } > INT54 type = VECT_INIT .reset : {} > RESET /* MSP430 Reset vector */ } /****************************************************************************/ /* MPU Specific memory segment definitons */ /****************************************************************************/ #ifdef _MPU_ENABLE #ifdef _MPU_MANUAL mpusb1 = (_MPU_SEGB1 + 0x4000 - 0xFFFF - 1) * 32 / 0x4000 - 1 + 1; // Increment by 1 for Memory Size of x.5 mpusb2 = (_MPU_SEGB2 + 0x4000 - 0xFFFF - 1) * 32 / 0x4000 - 1 + 1; // Increment by 1 for Memory Size of x.5 __mpuseg = (mpusb2 << 8) | mpusb1; __mpusam = (_MPU_SAM0 << 12) + (_MPU_SAM3 << 8) + (_MPU_SAM2 << 4) + _MPU_SAM1; #else mpusb1 = (fram_ro_start + 0x4000 - 0xFFFF - 1) * 32 / 0x4000 - 1 + 1; // Increment by 1 for Memory Size of x.5 mpusb2 = (fram_rx_start + 0x4000 - 0xFFFF - 1) * 32 / 0x4000 - 1 + 1; // Increment by 1 for Memory Size of x.5 __mpuseg = (mpusb2 << 8) | mpusb1; __mpusam = 0x7513; #endif #endif /****************************************************************************/ /* Include peripherals memory map */ /****************************************************************************/ -l msp430fr5739.cmd
