Other Parts Discussed in Thread: MSP430FR5994
Hello Team,
I'm using a MSP Gang Programmer to load the MSP430FR5994 IC with a specific hex file and am facing an issue on repeated loading of the file.
For a fresh board/UUT, the test passes along with the verify step and I have no problem (I am setting the erase mode to 1/All memory locations).
However, when I run the test again with the same code file, I get a GL.Verify error every time.
If, I click the erase option only to erase the UUT, then running the test (full test) yields a passing result.
I have checked the "Compare Code file and Flash Data" but no differences were found meaning some other memory locations have data that isn't FF.
I have automated the process using the dll but even after setting the config for Flash address to 1 (all memory locations), the Main process does not seem to clear this issue for me.
Please let me know what you think about this issue.
