Part Number: MSP430FR6043
Other Parts Discussed in Thread: MSP-FET
I am trying to connect my MSP430FR6043 to the USS design center on my PC but I am getting an "HID device detected, but could not connect to it" error.
When I press Connect, the first attempt fails and the second attempt gives me the message "HID device detected, but could not connect to it" error.
The same module and USS Design Center worked (connected) fine without much problem several months ago and I am not sure what's causing the problem.
I tried the following solution:
1) Connected the module on another PC - The module connected to the USS design center successfully
2) Changing USB Cable
3) Changing to a different port
4) Restarting PC
5) Uninstalling/Reinstalling USS design center
6) Used different module board
7) Used different version of the USS design center
Among the attempts listed above, nothing worked except for using a different PC.
This leads me to believe that the problem is with my PC but I have no idea what might be causing the issue.
Is there anything else that I can try to make this work?
