I'm using a MSP430F6721 during my reseach. Could anyone show me how to enter Low Power Mode 3.5 or 4.5?And how could I know whether if it enters? I have read the user guide for many times but still cannot enter LPMx.5. :(
With Regards.
With Regards.
The basic procedure is:
Disable everything that requires SMCLK.
For LPM4.5, do the same for everything that uses ACLK
Enable an interrupt source that does not depend on the disabled clocks
Clear GIE
Set the PMMREGOFF bit
enter LPM3 or LPM4
The tricky part is to properly wake up from LPMx.5 again, as you need to detect whether you are started from LPMx.5 or from a power off (check SYSRSTIV). In the fist case, the control registers of most peripherals have no effect until you clear the LOCKLPM5 bit.
However, there has been at least one recent thread about this topic and you should use the forum search to look there.
