MSP430FR5947: MSP430Flasher.exe error code 59 when writing to BSL area
Part Number: MSP430FR5947
Other Parts Discussed in Thread: MSP-FET
I get an MSP430Flasher.exe error code 59 when writing to MSP430FR5947 BSL area ???
Please can you help
Richard.
Background: Evaluating MSP-FET programmer for use on project to program customer boards. I can successfully write to the INFO,MAIN,RAM areas but not the BSL area. Using pin connections 1,4,7,9 on MSP-FET programmer.
Step 1) Read back the BSL area on customer board to a TI-TXT file using command below [placed listing of the file readback at end of bottom of this email]:
C:\TI\MSPFlasher_1.3.11\MSP430Flasher.exe -n MSP430FR5947 -i USB -j fast -r [zzzBSL.txt,BSL] -g
Step 2) Erase device and write the BSL file read out in Step 1) back into device with command below:
C:\TI\MSPFlasher_1.3.11\MSP430Flasher.exe -n MSP430FR5947 -i USB -j fast -e ERASE_TOTAL -w zzzBSL.txt -v -g -b -u
*     / |__        *
*    /_   /   MSP Flasher v1.3.11                                             *
* Evaluating triggers...done
* Checking for available FET debuggers:
* Found USB FET @ COM3 <- Selected
* Initializing interface @ COM3...done
* Setting FET speed...done
* Checking firmware compatibility:
* FET firmware is up to date.
* Reading FW version...done
* Setting VCC to 3000 mV...done
* Performing total erase...done
* Accessing device...done
* Reading device information...done
* Unlocking BSL memory...done
* Unlocking Info Memory A...done
* Loading file into device...
# Exit: 59
# ERROR: Could not write device memory
* Powering down...done
* Disconnecting from device...done
* Driver      : closed (No error)
zzzBSL.txt BSL File listed below:
@1000
09 3C 12 3C FF 3F FF 3F FF 3F FF 3F FF 3F FF 3F
00 07 34 B2 31 40 00 20 B0 13 22 17 0C 93 00 24
B0 13 B2 16 B0 13 B6 17 3D 90 AD DE 06 20 3E 90
EF BE 03 20 3C 41 3D 41 10 01 0C 43 0D 43 10 01
3B 15 09 3C 4C 43 B0 13 8A 17 D2 B3 CA 05 FD 2F
4C 4E B0 13 34 14 C2 43 1C 1D 0F 43 0C 43 92 B3
DC 05 FD 2B 92 C3 DC 05 1E 42 CC 05 0F 93 0F 20
7E 90 80 00 02 20 1F 43 F2 3F 7C 40 51 00 B0 13
8A 17 E2 43 1C 1D 5C 42 1C 1D 38 17 10 01 4D 4E
1F 93 04 20 82 4D 10 1C 2F 43 E1 3F 4A 4E 47 18
0A 5A 0B 4F 1B 53 2F 93 0F 20 82 DA 10 1C 82 93
10 1C 03 20 7C 40 53 00 E2 3F B2 90 05 01 10 1C
3A 28 7C 40 54 00 DB 3F 18 42 10 1C 38 50 03 00
0F 98 03 20 0C 4D 0F 4B C2 3F 18 42 0C 1C 1D 42
10 1C 2D 52 0F 9D 24 20 0C DA B0 13 FA 16 4C 93
1C 24 6E 48 7E F0 F0 00 7E 90 50 00 10 20 F8 90
52 00 00 00 A8 23 5E 48 01 00 4F 4E 6F 83 7F 90
05 00 98 2B 7C 40 56 00 B0 13 8A 17 9C 3F 4C 43
B0 13 8A 17 D2 43 1C 1D AE 3F 7C 40 52 00 A7 3F
08 5F C8 4E FD FF 0F 4B C2 93 1C 1D A4 23 8F 3F
03 43 0A 12 21 83 1F 42 08 1C 0F 93 0C 20 7C 90
80 00 26 24 7C 40 51 00 B0 13 A4 17 E2 43 1C 1D
21 53 3A 41 10 01 4E 4C 1F 93 03 20 82 4E 10 1C
17 3C 4D 4C 47 18 0D 5D 2F 93 15 20 82 DD 10 1C
82 93 10 1C 03 20 7C 40 53 00 06 3C B2 90 05 01
10 1C 06 28 7C 40 54 00 B0 13 A4 17 E2 43 1C 1D
92 53 08 1C DD 3F 1A 42 10 1C 3A 50 03 00 0F 9A
03 20 81 4E 00 00 F4 3F 1E 42 10 1C 2E 52 0F 9E
11 20 2D D1 81 4D 00 00 2C 41 B0 13 FA 16 4C 93
06 24 4C 43 B0 13 A4 17 D2 43 1C 1D C1 3F 7C 40
52 00 BA 3F CF 4C 1B 1D DB 3F 03 43 1B 15 1F 42
0C 1C 5B 4F 03 00 5E 4F 01 00 5C 4F 02 00 0D 43
B0 13 98 17 0C DE 0D DB 0E 4F 2E 52 6A 4F 7A 80
10 00 22 24 5A 83 0E 24 6A 82 22 24 5A 83 23 24
5A 83 11 24 5A 83 24 24 5A 83 25 24 6A 83 2A 20
5F 43 13 3C 1F 53 0C 4F B0 13 0E 15 4C 93 08 24
7C 40 05 00 21 3C B0 13 AE 17 04 20 B0 13 BA 17
4C 43 1A 3C 6C 42 18 3C 4F 43 B0 13 70 15 16 3C
B0 13 7C 17 11 3C B0 13 6E 17 B0 13 A4 14 0E 3C
B0 13 6E 17 04 3C 2E 42 3C 40 10 10 0D 43 B0 13
90 12 04 3C 7C 40 07 00 B0 13 40 17 1A 17 10 01
7B 15 21 83 06 4C 07 4D 08 4C 09 4D 08 5E 09 63
C1 43 00 00 0A 3C 1F 42 0E 1C FF 40 3A 00 00 00
1C 53 B0 13 58 17 06 4A 07 4B 07 99 03 28 37 20
06 98 35 2C C1 93 00 00 32 20 0E 48 0F 49 0E 86
0F 77 03 20 3E 90 04 01 03 28 3C 40 03 01 02 3C
0C 48 0C 86 14 42 0E 1C 14 53 0A 4C 0B 43 0A 56
0B 67 0E 4A 0F 4B 0B 3C 1F 15 05 16 6D 45 4D 12
0D 4E 0D 86 05 44 05 5D 7D 41 C5 4D 00 00 3E 53
3F 63 0F 97 C8 2B 02 20 0E 96 C5 2B B0 13 AE 17
EB 27 E1 42 00 00 6C 42 B0 13 40 17 C4 3F 21 53
74 17 10 01 0A 12 1E 42 06 1C FE 40 80 00 12 1C
1E 53 CE 4C 12 1C 1E 53 0F 4C 47 19 0F 10 CE 4F
12 1C 1E 53 B2 43 54 01 0F 43 09 3C 1D 42 0E 1C
0D 5F E2 4D 52 01 EE 4D 12 1C 0E 4A 1F 53 0A 4E
1A 53 0F 9C F3 2B DE 42 54 01 12 1C 0E 4A DA 42
55 01 12 1C 1E 53 0D 43 0A 43 10 3C 1D 43 1F 42
6E 06 3F 80 06 00 FA 27 3F 80 12 00 07 20 0D 93
F6 27 5F 4A 12 1C 82 4F 4E 06 1A 53 0A 9E EF 3B
82 43 06 1C 3A 41 10 01 B2 40 00 A5 60 01 B2 40
46 00 62 01 82 43 66 01 B2 D0 33 00 64 01 F2 43
61 01 B2 40 1E 1D 0C 1C 5E 42 42 1A C2 4E 1D 1D
5E 93 1F 20 82 43 06 1C 82 43 08 1C 82 43 0A 1C
F2 D0 C0 00 0C 02 C2 43 0A 02 92 D3 40 06 B2 40
00 07 40 06 5F 42 43 1A 3F D0 00 04 82 4F 54 06
92 C3 40 06 B2 D0 0F 00 6A 06 B2 40 16 1C 0E 1C
10 01 4E 93 06 20 6C 43 B0 13 34 14 B2 40 1E 1D
0E 1C 10 01 92 D3 C0 05 B2 D0 80 C0 C0 05 6C 83
09 24 5C 83 0E 24 5C 83 13 24 5C 83 18 24 5C 83
1C 24 20 3C B2 40 34 00 C6 05 B2 40 11 49 C8 05
19 3C B2 40 1A 00 C6 05 B2 40 01 B6 C8 05 12 3C
B2 40 0D 00 C6 05 B2 40 01 84 C8 05 0B 3C B2 42
C6 05 B2 40 A1 F7 C8 05 05 3C A2 42 C6 05 B2 40
51 55 C8 05 F2 D0 03 00 0D 02 C2 43 0B 02 92 C3
C0 05 10 01 3B 15 0A 4E B2 43 54 01 08 4C 09 4D
07 3C 19 15 0F 16 6E 4F C2 4E 52 01 18 53 09 63
0E 4C 0F 4D 0E 5A 0F 63 09 9F 03 28 09 20 08 9E
07 2C B0 13 AE 17 ED 27 6C 42 B0 13 40 17 15 3C
1E 42 54 01 1F 42 0E 1C FF 40 3A 00 00 00 1F 42
0E 1C CF 4E 01 00 47 18 0E 11 1F 42 0E 1C CF 4E
02 00 3C 40 03 00 B0 13 58 17 38 17 10 01 1B 15
21 83 0D 43 3A 40 E0 FF 0B 43 7E 4A 0F 4C 0F 5B
6F 4F 0E EF 0D DE 1B 53 3B 90 20 00 F6 2B 0D 93
10 20 B1 40 FF 7F 00 00 04 3C 2F 41 3F 53 81 4F
00 00 91 93 00 00 F9 37 B2 40 A5 A5 00 1C 4C 43
0C 3C B2 90 AA AA 84 FF 04 20 B2 90 AA AA 86 FF
02 24 B0 13 7C 17 7C 40 05 00 21 53 1A 17 10 01
0A 12 4A 4F B0 13 AE 17 25 20 92 42 02 1C A0 05
92 42 A8 05 04 1C B2 43 A8 05 F2 43 A1 05 4F 43
B2 90 05 00 10 1C 07 28 0F 4E 1E 42 10 1C 2E 82
B0 13 6A 16 4F 4C 4A 93 03 20 4C 4F B0 13 40 17
92 42 02 1C A0 05 92 42 04 1C A8 05 F2 43 A1 05
3A 41 10 01 6F 42 EF 3F 03 43 C2 43 1C 1D 04 3C
82 43 0A 1C 82 43 08 1C 1F 42 6E 06 3F 80 06 00
F7 27 3F 80 10 00 03 24 2F 83 0B 24 04 3C 1C 42
4C 06 B0 13 42 11 C2 93 1C 1D EE 27 5C 42 1C 1D
10 01 1F 42 0A 1C 1F 92 06 1C E6 2F 5F 4F 12 1C
82 4F 4E 06 92 53 0A 1C DF 3F 03 43 1B 15 0A 4C
7C 40 80 00 B0 13 8A 17 4C 4A B0 13 8A 17 0C 4A
47 19 0C 10 B0 13 8A 17 B2 43 54 01 0B 43 09 3C
1F 42 0E 1C 0F 5B E2 4F 52 01 6C 4F B0 13 8A 17
1B 53 0B 9A F5 2B 5C 42 54 01 B0 13 8A 17 5C 42
55 01 B0 13 8A 17 1A 17 10 01 7B 15 0A 4F 0A 5E
3A 53 3E 53 0F 43 66 4A 08 4E 09 4F 08 5C 09 6D
B0 13 AE 17 12 20 4B 43 19 15 07 16 C7 46 00 00
19 15 07 16 64 47 46 94 06 20 3A 53 3E 53 3F 63
0F 93 04 38 E8 3F 5B 43 01 3C 6B 42 4C 4B 74 17
10 01 F2 40 A5 00 21 01 92 C3 30 01 C2 43 21 01
82 43 00 1C B2 40 00 A5 02 1C B2 40 08 A5 40 01
F2 43 41 01 B0 13 B8 13 09 3C C2 93 1D 1D 02 20
B0 13 40 10 5C B3 02 28 B0 13 EC 11 D2 93 1D 1D
F4 23 B0 13 CA 15 F6 3F 03 43 B2 43 54 01 0F 43
06 3C 1E 42 0C 1C 0E 5F E2 4E 52 01 1F 53 1F 92
10 1C F7 2B 82 9C 54 01 02 24 4C 43 10 01 5C 43
10 01 B2 40 80 5A 5C 01 3F 40 00 1C 04 3C BF 40
4C 57 00 00 2F 53 0E 41 0F 91 F9 2B 0C 43 10 01
1F 42 0E 1C FF 40 3B 00 00 00 1F 42 0E 1C CF 4C
01 00 2C 43 80 00 58 17 D2 93 1D 1D 02 20 80 00
34 13 C2 93 1D 1D 02 20 B0 13 1C 16 10 01 6E 4E
5F 4F 05 00 47 18 0F 5F 0E DF 10 01 3E 40 EF BE
3D 40 AD DE 0C 43 80 00 02 1B A2 B3 DC 05 FD 2B
4C 4C 82 4C CE 05 10 01 4D EC 0D EC 8D 10 7C F3
8C 10 10 01 C2 4C 12 1C 92 43 06 1C 10 01 B2 90
A5 A5 00 1C 10 01 80 00 C2 17 1D 15 10 01 FF 3F
03 43 80 00 BE 17 FF FF FF FF FF FF FF FF FF FF
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
FF FF FF FF FF FF FF FF FF FF 00 10 FF FF FF FF
q
  • The BSL in the FR57xx, FR58xx, FR59xx, FR68xx, and FR69xx family is stored in read-only memory (ROM) and cannot be customized like some F5xx and F6xx family devices, where the BSL is stored in flash. More information is covered in the BSL User's Guide (SLAU550).
    Ryan
