MSP-FET: MSP-FET drivers for IAR 4.50.2 version
Part Number: MSP-FET
Good Morning TI community!
As you can see from the title I have some problems to install the suggested patch for the IAR 4.50.2 version to support MSP-FET Flash Emulation Tool.
I downloaded the patch for IAR from this link:
[FAQ] MSP-FET: SOLUTION: Using newer MSP-FETs with older CCS or IAR versions - MSP low-power microcontroller...
e2e.ti.com
Part Number: MSP-FET Other Parts Discussed in Thread: MSP430-FLASHER , **This is an informative post and all replies will be ignored. If you have questions or
but when I tried to install I have this problem:
The warning message is very strange for me because in the specified directory I have the 430 folder (as you can see below) so I don't understand why I have this message.
How can I do if I don't want to do the update to the latest version of the IAR IDE?
Thank you very much for your help.
Kind Regards,
Luigi
  • Luigi,
    The warning you're getting means that you do not have the proper permissions to make changes to the desired folder. If you right click on the intall tool and select run as administrator, it should fix your issue.
    Caleb Overbay
