MSP-EXP432P401R: MSP432 Launchpad - Error Uploading Energia Project to Launchpad
Part Number: MSP-EXP432P401R
I started playing around with the MSP432 Launchpad, I downloaded the drivers, Energia 1.6.10E18. I'm trying to run the multitasking example "MultiBlink" and I get the error below.
Energia: 1.6.10E18 (Windows 7), Board: "LaunchPad w/ msp432 EMT (48MHz)"
In file included from C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/sysbios/knl/Semaphore.h:52:0,
                 from C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/HardwareSerial.h:41,
                 from C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R\SerialObjects.cpp:33:
C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/xdc/std.h:63:36: warning: option '-Wstrict-prototypes' is valid for C/ObjC but not for C++ [-Wpragmas]
     #pragma GCC diagnostic ignored "-Wstrict-prototypes"
In file included from C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/sysbios/gates/GateMutex.h:53:0,
                 from C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/SPI.h:39,
                 from C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R\SpiObjects.cpp:33:
                 from C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/Wire.h:40,
                 from C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R\WireObjects.cpp:33:
C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432\ti\runtime\wiring\random.c:83:6: error: conflicting types for 'srandom'
 void srandom(unsigned long seed)
In file included from c:\users\a0221623\appdata\local\energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620\arm-none-eabi\include\stdlib.h:11:0,
                 from C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432\ti\runtime\wiring\random.c:42:
c:\users\a0221623\appdata\local\energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620\arm-none-eabi\include\stdlib.h:257:7: note: previous declaration of 'srandom' was here
 _VOID _EXFUN(srandom,(unsigned));
exit status 1
Error compiling for board LaunchPad w/ msp432 EMT (48MHz).
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
exit status 1Error compiling for board LaunchPad w/ msp432 EMT (48MHz).
This report would have more information with"Show verbose output during compilation"option enabled in File -> Preferences.
  • Energia: 1.6.10E18 (Windows 7), Board: "LaunchPad w/ msp432 EMT (48MHz)"
    C:\TI\energia-1.6.10E18\arduino-builder -dump-prefs -logger=machine -hardware "C:\TI\energia-1.6.10E18\hardware" -hardware "C:\Users\a0221623\AppData\Local\Energia15\packages" -tools "C:\TI\energia-1.6.10E18\tools-builder" -tools "C:\TI\energia-1.6.10E18\hardware\tools\msp430" -tools "C:\Users\a0221623\AppData\Local\Energia15\packages" -built-in-libraries "C:\TI\energia-1.6.10E18\libraries" -libraries "C:\Users\a0221623\Documents\Energia\libraries" -fqbn=energia:msp432:MSP-EXP432P401R -ide-version=10610 -build-path "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\TI\energia-1.6.10E18\examples\10.MultiTasking\MultiBlink\MultiBlink.ino"
    C:\TI\energia-1.6.10E18\arduino-builder -compile -logger=machine -hardware "C:\TI\energia-1.6.10E18\hardware" -hardware "C:\Users\a0221623\AppData\Local\Energia15\packages" -tools "C:\TI\energia-1.6.10E18\tools-builder" -tools "C:\TI\energia-1.6.10E18\hardware\tools\msp430" -tools "C:\Users\a0221623\AppData\Local\Energia15\packages" -built-in-libraries "C:\TI\energia-1.6.10E18\libraries" -libraries "C:\Users\a0221623\Documents\Energia\libraries" -fqbn=energia:msp432:MSP-EXP432P401R -ide-version=10610 -build-path "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\TI\energia-1.6.10E18\examples\10.MultiTasking\MultiBlink\MultiBlink.ino"
    Using board 'MSP-EXP432P401R' from platform in folder: C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0
    Using core 'msp432' from platform in folder: C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0
    Detecting libraries used...
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -w -x c++ -E -CC -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\sketch\MultiBlink.ino.cpp" -o "nul"
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -w -x c++ -E -CC -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\sketch\main.cpp" -o "nul"
    Generating function prototypes...
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -w -x c++ -E -CC -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\sketch\MultiBlink.ino.cpp" -o "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
    "C:\TI\energia-1.6.10E18\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "java" "-jar" "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\ino2cpp\1.0.2/ino2cpp.jar" -o "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp/sketch/" -T "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\ino2cpp\1.0.2/templates/Variables.mk.template" -r "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\ino2cpp\1.0.2" -n MultiBlink.ino "C:\TI\energia-1.6.10E18\examples\10.MultiTasking\MultiBlink" msp432:MSP_EXP432P401R"
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\sketch\MultiBlink.ino.cpp" -o "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\sketch\MultiBlink.ino.cpp.o"
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\sketch\main.cpp" -o "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\sketch\main.cpp.o"
    Compiling libraries...
    Compiling core...
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R\Board_init.c" -o "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\core\Board_init.c.o"
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R\pins.c" -o "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\core\pins.c.o"
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R\package\package_ti.runtime.wiring.msp432.variants.MSP_EXP432P401R.c" -o "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\core\package\package_ti.runtime.wiring.msp432.variants.MSP_EXP432P401R.c.o"
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R\SerialObjects.cpp" -o "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\core\SerialObjects.cpp.o"
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R\SpiObjects.cpp" -o "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\core\SpiObjects.cpp.o"
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-g++" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R\WireObjects.cpp" -o "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\core\WireObjects.cpp.o"
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432\ti\runtime\wiring\WInterrupts.c" -o "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\core\ti\runtime\wiring\WInterrupts.c.o"
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432\ti\runtime\wiring\itoa.c" -o "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\core\ti\runtime\wiring\itoa.c.o"
    "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\tools\arm-none-eabi-gcc\6.3.1-20170620/bin/arm-none-eabi-gcc" -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -mabi=aapcs -g -Dxdc_target_types__=gnu/targets/arm/std.h -Dxdc_target_name__=M4F -Dxdc_cfg__xheader__="configPkg/package/cfg/energia_pm4fg.h" -DTARGET_IS_MSP432P4XX -DBOARD_MSP_EXP432P401R -Dxdc__nolocalstring=1 -D__MSP432P401R__ -DCORE_VERSION=380 -c -g -Os -w -ffunction-sections -fdata-sections -mcpu=cortex-m4 -mthumb -DF_CPU=48000000L -DARDUINO=10610 -DENERGIA=10610 -DENERGIA_MSP_EXP432P401R -DENERGIA_ARCH_MSP432 "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432/ti/runtime/wiring/msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib/MSP432P4xx" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/driverlib" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system/inc/CMSIS/" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\system" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432" "-IC:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\variants\MSP_EXP432P401R" "C:\Users\a0221623\AppData\Local\Energia15\packages\energia\hardware\msp432\3.8.0\cores\msp432\ti\runtime\wiring\random.c" -o "C:\Users\a0221623\AppData\Local\Temp\build76d431ba25888b4bcc04f79cb5c39a4d.tmp\core\ti\runtime\wiring\random.c.o"
    exit status 1
  • Luis,
    Can you verify that you installed the Energia MSP432 _EMT_ files (and not just the regular MSP432 board files)?
    -Bob L.
  • Luis,
    For reference, if I install both the EMT and non-EMT MSP432 Board files into my Energia v1.6.10E18 install, I can successfully compile.
    Let me know what you get when trying to compile under those conditions.
    -Bob L>
  • Bob,
    See attached image. I have both EMT and non-EMT boards installed.
    -Luis
  • Bob,
    I ended uninstalling Energia, and I deleted the Energia15 folder created under C:users/.../Appdata/Energia15.
    Then I started the process from zero installing everything again.
    This seems to have solved it.
    Note: the program only works with the RED MSP432.
    Thanks!
    Luis
