I am trying to use the "launchpad out of box demo"
I have a device that is on the list at the Exosite server.
but I can Not get My device to connect/ get a token.
I get the following message from my devices Com Port
Connecting to server...[1K
Connected te server.
> [1K
No Token found in EEPROM.
> [1K
CloudError: Server sent 409 error.
Check if board is added to the Exosite server.
> [1K
Re-enable the device for provisioning on Exosite server.
> [1K
Copy a temporary token from Exosite server to the LaunchPad using the comman
d "Token".
> [1K
> [1K
> [1K
d "Token".
> [1K
> [1K
> [1K
d "Token".
> [1K
CloudTask: Bad response, ecode: -112 during : 1 action.
Resetting connection.
> [1K
Connected to Exosite server.
> [1K
> [1K
> [1K
Failed to resolve host name. Check proxy server settings. Ecode: -106.
I do not have a "Proxy Server"
Provisioning is enabled
I tried entering a key from the Exosite server using the Token Command
I see my device on the Exosite server
under setting I found the following
Note: Devices that attempt to connect that do not match this format will be ignored for security reasons.
Help!
Hello Jason,
Based on the error message, it could be one of the following two:
Sai
