Part Number: MSP432P4111
Hi all,
Our msp432 currently has two bin files residing in its memory. The first one being a boot bin file which switches to the main bin file located at a the memory location
* Copyright (C) 2012 - 2018 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* GCC linker script for Texas Instruments MSP432P4111
* File creation date: 01/26/18
MEMORY
MAIN_FLASH (RX) : ORIGIN = 0x00080000, LENGTH = 0x00200000
INFO_FLASH (RX) : ORIGIN = 0x00200000, LENGTH = 0x00004000
SRAM_CODE (RWX): ORIGIN = 0x01000000, LENGTH = 0x00010000
SRAM_DATA (RW) : ORIGIN = 0x20000000, LENGTH = 0x00040000
REGION_ALIAS("REGION_TEXT", MAIN_FLASH);
REGION_ALIAS("REGION_INFO", INFO_FLASH);
REGION_ALIAS("REGION_BSS", SRAM_DATA);
REGION_ALIAS("REGION_DATA", SRAM_DATA);
REGION_ALIAS("REGION_STACK", SRAM_DATA);
REGION_ALIAS("REGION_HEAP", SRAM_DATA);
REGION_ALIAS("REGION_ARM_EXIDX", MAIN_FLASH);
REGION_ALIAS("REGION_ARM_EXTAB", MAIN_FLASH);
SECTIONS {
/* section for the interrupt vector area */
PROVIDE (_intvecs_base_address =
DEFINED(_intvecs_base_address) ? _intvecs_base_address : 0x00080000);
.intvecs (_intvecs_base_address) : AT (_intvecs_base_address) {
KEEP (*(.intvecs))
} > REGION_TEXT
/* The following three sections show the usage of the INFO flash memory */
/* INFO flash memory is intended to be used for the following */
/* device specific purposes: */
/* Flash mailbox for device security operations */
PROVIDE (_mailbox_base_address = 0x00200000);
.flashMailbox (_mailbox_base_address) : AT (_mailbox_base_address) {
KEEP (*(.flashMailbox))
} > REGION_TEXT
/* TLV table for device identification and characterization */
PROVIDE (_tlv_base_address = 0x00201000);
.tlvTable (_tlv_base_address) (NOLOAD) : AT (_tlv_base_address) {
KEEP (*(.tlvTable))
} > REGION_TEXT
/* BSL area for device bootstrap loader */
PROVIDE (_bsl_base_address = 0x00202000);
.bslArea (_bsl_base_address) : AT (_bsl_base_address) {
KEEP (*(.bslArea))
} > REGION_TEXT
PROVIDE (_vtable_base_address =
DEFINED(_vtable_base_address) ? _vtable_base_address : 0x20000000);
.vtable (_vtable_base_address) : AT (_vtable_base_address) {
KEEP (*(.vtable))
} > REGION_DATA
.text : {
CREATE_OBJECT_SYMBOLS
KEEP (*(.text))
*(.text.*)
. = ALIGN(0x4);
KEEP (*(.ctors))
. = ALIGN(0x4);
KEEP (*(.dtors))
. = ALIGN(0x4);
__init_array_start = .;
KEEP (*(.init_array*))
__init_array_end = .;
KEEP (*(.init))
KEEP (*(.fini*))
} > REGION_TEXT AT> REGION_TEXT
.rodata : {
*(.rodata)
*(.rodata.*)
.ARM.exidx : {
__exidx_start = .;
*(.ARM.exidx* .gnu.linkonce.armexidx.*)
__exidx_end = .;
} > REGION_ARM_EXIDX AT> REGION_ARM_EXIDX
.ARM.extab : {
KEEP (*(.ARM.extab* .gnu.linkonce.armextab.*))
} > REGION_ARM_EXTAB AT> REGION_ARM_EXTAB
__etext = .;
.data : {
__data_load__ = LOADADDR (.data);
__data_start__ = .;
KEEP (*(.data))
KEEP (*(.data*))
. = ALIGN (4);
__data_end__ = .;
} > REGION_DATA AT> REGION_TEXT
.bss : {
__bss_start__ = .;
*(.shbss)
KEEP (*(.bss))
*(.bss.*)
*(COMMON)
. = ALIGN (4);
__bss_end__ = .;
} > REGION_BSS AT> REGION_BSS
.heap : {
__heap_start__ = .;
end = __heap_start__;
_end = end;
__end = end;
KEEP (*(.heap))
__heap_end__ = .;
__HeapLimit = __heap_end__;
} > REGION_HEAP AT> REGION_HEAP
.stack (NOLOAD) : ALIGN(0x8) {
_stack = .;
KEEP(*(.stack))
} > REGION_STACK AT> REGION_STACK
__StackTop = ORIGIN(REGION_STACK) + LENGTH(REGION_STACK);
PROVIDE(__stack = __StackTop);
* are met:
* distribution.
MEMORY
BOOT_FLASH (RX) : ORIGIN = 0x00000000, LENGTH = 0x00080000
INFO_FLASH (RX) : ORIGIN = 0x00200000, LENGTH = 0x00008000
SRAM_CODE (RWX): ORIGIN = 0x01000000, LENGTH = 0x00040000
SRAM_DATA (RW) : ORIGIN = 0x20000000, LENGTH = 0x00010000
REGION_ALIAS("REGION_TEXT", BOOT_FLASH);
REGION_ALIAS("REGION_INFO", BOOT_FLASH);
REGION_ALIAS("REGION_ARM_EXIDX", BOOT_FLASH);
REGION_ALIAS("REGION_ARM_EXTAB", BOOT_FLASH);
SECTIONS {
DEFINED(_intvecs_base_address) ? _intvecs_base_address : 0x0);
KEEP (*(.intvecs))
} > REGION_TEXT
PROVIDE (_mailbox_base_address = 0x200000);
} > REGION_TEXT
KEEP (*(.tlvTable))
} > REGION_TEXT
KEEP (*(.bslArea))
} > REGION_TEXT
KEEP (*(.vtable))
} > REGION_DATA
.text : {
KEEP (*(.text))
*(.text.*)
. = ALIGN(0x4);
KEEP (*(.ctors))
. = ALIGN(0x4);
KEEP (*(.dtors))
. = ALIGN(0x4);
KEEP (*(.init))
KEEP (*(.fini*))
.rodata : {
*(.rodata)
*(.rodata.*)
.ARM.exidx : {
__exidx_start = .;
__exidx_end = .;
.ARM.extab : {
__etext = .;
.data : {
__data_start__ = .;
KEEP (*(.data))
KEEP (*(.data*))
. = ALIGN (4);
__data_end__ = .;
.bss : {
__bss_start__ = .;
*(.shbss)
KEEP (*(.bss))
*(.bss.*)
*(COMMON)
. = ALIGN (4);
__bss_end__ = .;
.heap : {
__heap_start__ = .;
_end = end;
__end = end;
KEEP (*(.heap))
__heap_end__ = .;
_stack = .;
KEEP(*(.stack))
