Hi team,
my customer is using the MSP430F147 and hava a few questions about it:
The datasheet SLAS242F shows the representation of the supply Voltage and the frequency. Now at the new datasheet the Figure 5-1 has changed.
SLAS272F
What has the component been changed? That now it is possible to set the Supply Voltage at 3.2V and the frequency at 8MHz?
We have the problem that the MSP430F147 is supplied with 3.3V and with an 8MHz crystal. There are some times failures at power-up. If we change the clock rate to 4MHz, there are no problems.
At the datasheet is no revision History why this has changed. Why it is changed at the datasheet?
Thank you and kind regards,
Felix
