Hi
I am designing 300W battery charger for EV application .The topology i selected is Forward Converter.Following are my main queries
1.Does forward converter topology is equivalent to buck converter with isolation?
2.What is the formula to calculate ESR of output capacitor .Is it ripple voltage /ripple load current or ripple voltage /ripple lnductor current
3.As my control loop is digital ,how should i simulate and calculate PID parameter when loop switch from constant current to constant voltage
4.Are their any standard to specify maximum ripple in current and voltage for Li ion battery charging
5.Can a boost converter be used for Li ion charging,if yes can you explain that
Mudit Mittal
