I am trying to use a modified TCP echo example to write data using TCP. My code is in c++ and need to use extern C on my interrupt handlers. I am getting a problem where the code is going into the default handler when trying to execute the tcp_write function. The tcp write function works fine in the call back functions but they dont work when I try to use it outside those functions(in the main loop).
