Hi Team,
When the DRV8350S is working with a motor, the chip will report GDUV error when the 48V power supply is turned on for about ten seconds, and the restart is useless, and the chip is damaged.
Annie
Hi Annie,
This looks like the same schematic as in Hiram's question: https://e2e.ti.com/support/motor-drivers-group/motor-drivers/f/motor-drivers-forum/1000569/drv8350-drv8350
I have some things for you to try:
Matt
Hi Matt,
Customer would like to know what internal principle causes the chip damage? He found that the VGLS pin state impedance of the bad veneer is abnormal. He suspects that the internal output VGLS LDO is damaged. Would you share your suggestion for this?
Annie
Hello Annie,
Matt
Hi Annie,
Changing from 2.2 ohms to 75 ohms reduces then gate drive current. This will relate to my first bullet point above:
Matt
Hi Matt,
The customer adjusted the size of IDRIVE on the software, from 2000ma to 100ma, the waveform has not changed during the whole process, and the situation has not improved. He had to increase the drive resistance, but this would make the dead zone very long.
Annie
Hi Annie,
Adjusting the series resistance and adjusting the IDIRVE will have the same effect. Please ensure that the customer is adjusting both the source and sink settings (there are four different registers). For example, the sink setting can be adjusted from 2000mA down to 100mA while the source setting can be adjusted from 1000mA down to 50mA.
Original setting: 2.2 ohms, 1000mA/2000mA:
New setting: 75 ohms, 1000mA/2000mA:
New setting: 2.2 ohms, 100mA/100mA (did the customer adjust both the sink and source IDIRVE?):
Matt
