Other Parts Discussed in Thread: MSP430F5529, DRV832X, , DRV8320
I am controlling the DRV8320S motor driver with the MCP430F5529LP development board through the code, but I cannot read the correct current from the ISEN pin.
I looked at the current reading side of the DRV832X_MSP430F5529_Trapezoidal_Sensored_BLDC example, as far as I understand, you are reading over phase A. Why did you do it like this?
ADC settings I use.
void ADC12_init(void) { GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P6,GPIO_PIN0); GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P6,GPIO_PIN1); GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P6,GPIO_PIN2); GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P6,GPIO_PIN5); GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P6,GPIO_PIN6); GPIO_setAsPeripheralModuleFunctionInputPin(GPIO_PORT_P7,GPIO_PIN0); ADC12_A_configureMemoryParam CH0_configureMemoryParam = {0}; ADC12_A_configureMemoryParam CH1_configureMemoryParam = {0}; ADC12_A_configureMemoryParam CH2_configureMemoryParam = {0}; ADC12_A_configureMemoryParam CH3_configureMemoryParam = {0}; ADC12_A_configureMemoryParam CH4_configureMemoryParam = {0}; ADC12_A_configureMemoryParam CH5_configureMemoryParam = {0}; CH0_configureMemoryParam.memoryBufferControlIndex = ADC12_A_MEMORY_0; CH0_configureMemoryParam.inputSourceSelect = ADC12_A_INPUT_A0; CH0_configureMemoryParam.positiveRefVoltageSourceSelect = ADC12_A_VREFPOS_AVCC; CH0_configureMemoryParam.negativeRefVoltageSourceSelect = ADC12_A_VREFNEG_AVSS; CH0_configureMemoryParam.endOfSequence = ADC12_A_NOTENDOFSEQUENCE; CH1_configureMemoryParam.memoryBufferControlIndex = ADC12_A_MEMORY_1; CH1_configureMemoryParam.inputSourceSelect = ADC12_A_INPUT_A1; CH1_configureMemoryParam.positiveRefVoltageSourceSelect = ADC12_A_VREFPOS_AVCC; CH1_configureMemoryParam.negativeRefVoltageSourceSelect = ADC12_A_VREFNEG_AVSS; CH1_configureMemoryParam.endOfSequence = ADC12_A_NOTENDOFSEQUENCE; CH2_configureMemoryParam.memoryBufferControlIndex = ADC12_A_MEMORY_2; CH2_configureMemoryParam.inputSourceSelect = ADC12_A_INPUT_A2; CH2_configureMemoryParam.positiveRefVoltageSourceSelect = ADC12_A_VREFPOS_AVCC; CH2_configureMemoryParam.negativeRefVoltageSourceSelect = ADC12_A_VREFNEG_AVSS; CH2_configureMemoryParam.endOfSequence = ADC12_A_NOTENDOFSEQUENCE; CH3_configureMemoryParam.memoryBufferControlIndex = ADC12_A_MEMORY_5; CH3_configureMemoryParam.inputSourceSelect = ADC12_A_INPUT_A5; CH3_configureMemoryParam.positiveRefVoltageSourceSelect = ADC12_A_VREFPOS_AVCC; CH3_configureMemoryParam.negativeRefVoltageSourceSelect = ADC12_A_VREFNEG_AVSS; CH3_configureMemoryParam.endOfSequence = ADC12_A_NOTENDOFSEQUENCE; CH4_configureMemoryParam.memoryBufferControlIndex = ADC12_A_MEMORY_6; CH4_configureMemoryParam.inputSourceSelect = ADC12_A_INPUT_A6; CH4_configureMemoryParam.positiveRefVoltageSourceSelect = ADC12_A_VREFPOS_AVCC; CH4_configureMemoryParam.negativeRefVoltageSourceSelect = ADC12_A_VREFNEG_AVSS; CH4_configureMemoryParam.endOfSequence = ADC12_A_NOTENDOFSEQUENCE; CH5_configureMemoryParam.memoryBufferControlIndex = ADC12_A_MEMORY_12; CH5_configureMemoryParam.inputSourceSelect = ADC12_A_INPUT_A12; CH5_configureMemoryParam.positiveRefVoltageSourceSelect = ADC12_A_VREFPOS_AVCC; CH5_configureMemoryParam.negativeRefVoltageSourceSelect = ADC12_A_VREFNEG_AVSS; CH5_configureMemoryParam.endOfSequence = ADC12_A_NOTENDOFSEQUENCE; ADC12_A_init(ADC12_A_BASE,ADC12_A_SAMPLEHOLDSOURCE_SC,ADC12_A_CLOCKSOURCE_ACLK,ADC12_A_CLOCKDIVIDER_1); ADC12_A_setupSamplingTimer(ADC12_A_BASE,ADC12_A_CYCLEHOLD_256_CYCLES,ADC12_A_CYCLEHOLD_4_CYCLES,ADC12_A_MULTIPLESAMPLESENABLE); ADC12_A_setResolution(ADC12_A_BASE,ADC12_A_RESOLUTION_12BIT); ADC12_A_configureMemory(ADC12_A_BASE,&CH0_configureMemoryParam); ADC12_A_configureMemory(ADC12_A_BASE,&CH1_configureMemoryParam); ADC12_A_configureMemory(ADC12_A_BASE,&CH2_configureMemoryParam); ADC12_A_configureMemory(ADC12_A_BASE,&CH3_configureMemoryParam); ADC12_A_configureMemory(ADC12_A_BASE,&CH4_configureMemoryParam); ADC12_A_configureMemory(ADC12_A_BASE,&CH5_configureMemoryParam); /* VSENA */ ADC12_A_clearInterrupt(ADC12_A_BASE,ADC12IFG0); ADC12_A_enableInterrupt(ADC12_A_BASE,ADC12IE0); /* VSENB */ ADC12_A_clearInterrupt(ADC12_A_BASE,ADC12IFG1); ADC12_A_enableInterrupt(ADC12_A_BASE,ADC12IE1); /* VSENC */ ADC12_A_clearInterrupt(ADC12_A_BASE,ADC12IFG2); ADC12_A_enableInterrupt(ADC12_A_BASE,ADC12IE2); /* VSENVM */ ADC12_A_clearInterrupt(ADC12_A_BASE,ADC12IFG5); ADC12_A_enableInterrupt(ADC12_A_BASE,ADC12IE5); /* POT */ ADC12_A_clearInterrupt(ADC12_A_BASE,ADC12IFG6); ADC12_A_enableInterrupt(ADC12_A_BASE,ADC12IE6); /* ISEN */ ADC12_A_clearInterrupt(ADC12_A_BASE,ADC12IFG12); ADC12_A_enableInterrupt(ADC12_A_BASE,ADC12IE12); __enable_interrupt(); ADC12_A_enable(ADC12_A_BASE); ADC12_A_startConversion(ADC12_A_BASE, ADC12_A_MEMORY_0 | ADC12_A_MEMORY_1 | ADC12_A_MEMORY_2 | ADC12_A_MEMORY_5 | ADC12_A_MEMORY_6 | ADC12_A_MEMORY_12, ADC12_A_REPEATED_SEQOFCHANNELS); }
ADC interrupt
#pragma vector = ADC12_VECTOR __interrupt void ADC12ISR (void) { switch (__even_in_range(ADC12IV, 34)) { case 0: break; //Vector 0: No interrupt case 2: break; //Vector 2: ADC overflow case 4: break; //Vector 4: ADC timing overflow case 6: phaseA = ADC12_A_getResults(ADC12_A_BASE,ADC12_A_MEMORY_0); break; //Vector 6: ADC12IFG0 case 8: phaseB = ADC12_A_getResults(ADC12_A_BASE,ADC12_A_MEMORY_1); break; //Vector 8: ADC12IFG1 case 10: phaseC = ADC12_A_getResults(ADC12_A_BASE,ADC12_A_MEMORY_2); break; //Vector 10: ADC12IFG2 case 12:break; //Vector 12: ADC12IFG3 case 14: break; //Vector 14: ADC12IFG4 case 16: //vccSupplyVoltage = ADC12_A_getResults(ADC12_A_BASE,ADC12_A_MEMORY_5); vccSupplyVoltage = ADC12_A_getResults(ADC12_A_BASE,ADC12_A_MEMORY_5) * 0.014; break; //Vector 16: ADC12IFG5 case 18: drvPOT = ADC12_A_getResults(ADC12_A_BASE,ADC12_A_MEMORY_6); if( POT_counter <= 5) POT_Toplam += ADC12_A_getResults(ADC12_A_BASE,ADC12_A_MEMORY_6); if( POT_counter == 5 ) POT_Ortalama = POT_Toplam/5; if( POT_counter > 5 ) POT_Ortalama = ( POT_Ortalama * 4 + ADC12_A_getResults(ADC12_A_BASE,ADC12_A_MEMORY_6)) / 5; if( POT_counter < 6) POT_counter++; //PWM = POT_Ortalama / 25.6; break; //Vector 18: ADC12IFG6 case 20: break; //Vector 20: ADC12IFG7 case 22: break; //Vector 22: ADC12IFG8 case 24: break; //Vector 24: ADC12IFG9 case 26: break; //Vector 26: ADC12IFG10 case 28: break; //Vector 28: ADC12IFG11 case 30: //drvISEN = ADC12_A_getResults(ADC12_A_BASE,ADC12_A_MEMORY_12); if( ISEN_counter <= 5) ISEN_Toplam += ADC12_A_getResults(ADC12_A_BASE,ADC12_A_MEMORY_12); if( ISEN_counter == 5 ) ISEN_Ortalama = ISEN_Toplam/5; if( ISEN_counter > 5 ) ISEN_Ortalama = ( ISEN_Ortalama * 4 + ADC12_A_getResults(ADC12_A_BASE,ADC12_A_MEMORY_12)) / 5; if( ISEN_counter < 6) ISEN_counter++; drvISEN = ISEN_Ortalama; break; //Vector 30: ADC12IFG12 case 32: break; //Vector 32: ADC12IFG13 case 34: break; //Vector 34: ADC12IFG14 default: break; } }
While the engine is running, the adc value on the compiler is constantly changing. When I measure the ISEN pin with a multimeter, the value appears to be 75mA.
What is wrong here?
Ali,
