Hi team,
when device will indicate predriver fault when device is in indexer mode? In datasheet description, when in indexer mode, H bridge are disabled and xPDF will be set. Does it mean that in indexer mode, when power up, predriver fault will occur?
Customer use indexer mode and mosfet spec as attached, and configure register 0x06 as 0x005F, and then found device indicates predriver fault sometimes. could you pls help to check if customer configuration is wrong? Customer want to know why device indicated predriver fault. I also attached sch for your reference.
SPEC-00X-000XXX-00-M00133-1.pdf
Thanks~
Rayna
