I have Drv8320 driver but when I swap phases the motor does not move in reverse direction. As I changed the phases, I applied the same process on the HALL side, but I still get the same result. When I change my software the motor spins in the opposite direction. but I want to rotate the motor in reverse without changing my software. Can you help with the solution??
