MCF8316AEVM: [IPD_T1_FAULT] and [IPD_T2_FAULT]
Part Number: MCF8316AEVM
Other Parts Discussed in Thread: MCF8316A
I can successfully extract motor parameters using MPET: 2.4Ω, 1.8mH, 29mV/HZ. Manually enter the maximum speed: 240HZ.
Then IPD_T2_FAULT occurs when I give a speed via I2C, I'm sure the motor is connected to the device. Then I turn on the Tri-state(IPD_RLS_MODE), and give a speed via I2C, then IPD_T1_FAULT occurs. The whole process has never turned on auto read. Below is my json file.
  "signature": "oneui-register-data",
  "data": [
        "idx": 0,
        "id": "isd_config",
        "value": "0x44638C20"
        "idx": 1,
        "id": "rev_drive_config",
        "value": "0x283AF064"
        "idx": 2,
        "id": "motor_startup1",
        "value": "0x4B680FD0"
        "idx": 3,
        "id": "motor_startup2",
        "value": "0x5B066000"
        "idx": 4,
        "id": "closed_loop1",
        "value": "0x0C3181B0"
        "idx": 5,
        "id": "closed_loop2",
        "value": "0x1AADC3BA"
        "idx": 6,
        "id": "closed_loop3",
        "value": "0x2E800004"
        "idx": 7,
        "id": "closed_loop4",
        "value": "0x28DA05A0"
        "idx": 8,
        "id": "speed_profiles1",
        "value": "0x00000000"
        "idx": 9,
        "id": "speed_profiles2",
        "idx": 10,
        "id": "speed_profiles3",
        "idx": 11,
        "id": "speed_profiles4",
        "idx": 12,
        "id": "speed_profiles5",
        "idx": 13,
        "id": "speed_profiles6",
        "idx": 0,
        "id": "fault_config1",
        "value": "0x5DD80206"
        "idx": 1,
        "id": "fault_config2",
        "value": "0x74000000"
        "idx": 0,
        "id": "pin_config",
        "idx": 1,
        "id": "device_config1",
        "value": "0x00100000"
        "idx": 2,
        "id": "device_config2",
        "value": "0x0000B000"
        "idx": 3,
        "id": "peri_config1",
        "value": "0x40000000"
        "idx": 4,
        "id": "gd_config1",
        "value": "0x00000100"
        "idx": 5,
        "id": "gd_config2",
        "value": "0x00200000"
        "idx": 0,
        "id": "ana_trim3",
        "value": "0x48004800"
        "idx": 1,
        "id": "ana_trim4",
        "idx": 2,
        "id": "ana_trim5",
        "value": "0x00000009"
        "idx": 3,
        "id": "ana_trim6",
        "idx": 4,
        "id": "ana_trim7",
        "idx": 5,
        "id": "ana_trim8",
        "value": "0x00004AB3"
        "idx": 6,
        "id": "ana_trim9",
        "value": "0x0065A89E"
        "idx": 7,
        "id": "ana_trim10",
        "value": "0x53731039"
        "idx": 0,
        "id": "int_algo_1",
        "value": "0x00B3404D"
        "idx": 1,
        "id": "int_algo_2",
        "value": "0x000001A7"
        "idx": 0,
        "id": "gate_driver_fault_status",
        "idx": 1,
        "id": "controller_fault_status",
        "idx": 0,
        "id": "algo_status",
        "value": "0x2D981600"
        "idx": 1,
        "id": "mtr_params",
        "value": "0xC35DBA00"
        "idx": 2,
        "id": "algo_status_mpet",
        "value": "0xF3000000"
        "idx": 0,
        "id": "dev_ctrl",
        "value": "0x20000000"
        "idx": 0,
        "id": "algo_ctrl1",
        "value": "0x80000000"
        "idx": 1,
        "id": "algo_ctrl2",
        "idx": 2,
        "id": "current_pi",
        "value": "0x0006ED8C"
        "idx": 3,
        "id": "speed_pi",
        "value": "0x000DA228"
        "idx": 4,
        "id": "dac_1",
        "idx": 5,
        "id": "dac_2",
        "idx": 0,
        "id": "algorithm_state",
        "idx": 1,
        "id": "fg_speed_fdbk",
        "value": "0x00243D54"
        "idx": 2,
        "id": "bus_current",
        "idx": 3,
        "id": "phase_current_a",
        "value": "0x00020000"
        "idx": 4,
        "id": "phase_current_b",
        "value": "0xFFFE0000"
        "idx": 5,
        "id": "phase_current_c",
        "idx": 6,
        "id": "csa_gain_feedback",
        "value": "0x00010003"
        "idx": 7,
        "id": "voltage_gain_feedback",
        "value": "0x00000002"
        "idx": 8,
        "id": "vm_voltage",
        "value": "0x0191E000"
        "idx": 9,
        "id": "phase_voltage_va",
        "value": "0x00006ED9"
        "idx": 10,
        "id": "phase_voltage_vb",
        "value": "0x003C3052"
        "idx": 11,
        "id": "phase_voltage_vc",
        "value": "0x008B6E1A"
        "idx": 12,
        "id": "sin_commutation_angle",
        "value": "0xFD7C8664"
        "idx": 13,
        "id": "cos_commutation_angle",
        "value": "0x0797B10C"
        "idx": 14,
        "id": "ialpha",
        "value": "0x00610000"
        "idx": 15,
        "id": "ibeta",
        "value": "0x00BA7BF0"
        "idx": 16,
        "id": "valpha",
        "value": "0x002A16B6"
        "idx": 17,
        "id": "vbeta",
        "value": "0x008BAFC5"
        "idx": 18,
        "id": "id",
        "value": "0x001B2BB3"
        "idx": 19,
        "id": "iq",
        "value": "0x00D02DAE"
        "idx": 20,
        "id": "vd",
        "value": "0xFFFC0DC7"
        "idx": 21,
        "id": "vq",
        "value": "0x0091E062"
        "idx": 22,
        "id": "iq_ref_rotor_align",
        "idx": 23,
        "id": "speed_ref_open_loop",
        "idx": 24,
        "id": "iq_ref_open_loop",
        "value": "0x00A37561"
        "idx": 25,
        "id": "speed_ref_closed_loop",
        "idx": 26,
        "id": "id_ref_closed_loop",
        "idx": 27,
        "id": "iq_ref_closed_loop",
        "idx": 28,
        "id": "isd_state",
        "value": "0x00000003"
        "idx": 29,
        "id": "isd_speed",
        "value": "0x3FAA4098"
        "idx": 30,
        "id": "ipd_state",
        "value": "0x0000000B"
        "idx": 31,
        "id": "ipd_angle",
        "value": "0x05F5CF36"
        "idx": 32,
        "id": "ed",
        "idx": 33,
        "id": "eq",
        "idx": 34,
        "id": "speed_fdbk",
        "idx": 35,
        "id": "theta_est",
How can i solve this problem? Thank you so much.
Yunsheng Luo
