1.while the DRV8912QPWPRQ is operated normally, set the output 12 chs as high voltage , and the OCP status bit is not set.
2. short OUT3 pin to GND, the OCP bit is set.
3. we can't clear the OCP bit by CLR_FLT of CONFIG_CTRL register , and Ouput3 is turn off ,however, I can't set it as high again.
4. while OUT3 OCP happened ,HB3_HS_OCP is 1,HB3_LS_OCP is 0,nfault is low
