I need help from experts.
We use TLC5940 fro LED driver and have 2 questions:
1. The customer gave us a TLC5940 reference design: The TLC5940 OUTx connects LED through a serial resistor. And we follow their design. As I know the constant-current drive doesn't need a serial resistor for LED, the chip internal circuit will adjust the current. Will this serial resistor interfere the constant current drive? At least it will cause TLC5940 thermal problem, because now the Vout=LED forward voltage + resistor voltage drop. it will increase heat created on TLC5940.
2. The customer writes the software. When we build the prototype, can we test the board without their software? ie, the default grayscale brightness is set at full brightness, so the LED can light up? If we can test it, would you please instruct us how to configure (pull up or pull down) BLANK/DCPRG/VPRG/XLAT signals. Attached is our preliminary schematic (HWI schematic preliminary.pdf) and customer sample schematic (xxxx.png).
Thanks.
Chang
