Other Parts Discussed in Thread: TPS2514
Hi E2E,
Good day.
Our customer is using the BQ25895 charger and they’re trying to use its boost function with PMID pin and OTG. They would like to charge the phone using this PMID pin but they have a problem interfacing it with a USB connector. Is there a USB dedicated charging port controller to interface it with a USB connector or they will need another IC to do that? How that charger will detect the USB connector where the phone is plugged in? Is it correct to use TPS2514ADBVR, supplied by the PMID voltage, to interface with the USB connector? Please see the schematic attached.
Carlo
