Other Parts Discussed in Thread: TPS546D24, TPS53355, TPS543C20A
I am looking for a buck converter, that can step down an input voltage to 5V output, current 1A min. The converter will be inside an MRI room, but outside the 5G line, but I am still looking for an air core inductor based design, just to be avoid any saturation and magnetic pull on the ferrite core based designs.
I have across the recommended, TPS546D24AEVM-2PH, that has pretty low inductances and could be supported with air core inductors, but it seems to be an overkill for our current application. Are there any other EVM boards/ IC that are MRI compatible and use air core inductors?
Thank you for your suggestions!
Jas
