Hello.
I'm using this IC (TPS61222DCKT) to boost the battery voltage (3.3V to 4.2V) to +5.5V on the output. The idea is to power an LDO regulator for 5V and then power some low power sensors.
The problem is that in the output I have ~300mVpp and a ~6.8Vdc... not even close of 5.5Vdc.
* The schematic (I have added one more 10uF cap at the output):
https://i.ibb.co/8KRLW90/tps-1.png
* The layout:
https://i.ibb.co/F8q6HL7/tps-2.png
* Vin = 3.95VDC
* Vin AC signal:
https://i.ibb.co/c3kKnnm/SDS00011.png
* V_SW signal:
https://i.ibb.co/KsMM3sR/SDS00012.png
https://i.ibb.co/crJfH74/SDS00013.png
* Output voltage - DC:
https://i.ibb.co/mSRMkcy/SDS00014.png
* Output voltage - AC:
https://i.ibb.co/M8LStDv/SDS00015.png
How can I solve this problem? This does not make me any sense...
Thank you.
