Hi Team,
Can you please share Bq8050 datasheet?
We use in our battery pack. I can share schematic with you.
In certain cases the battery is going into deep discharge and not able to review by charging. I am wondering, what could be the no point of return state in the deep discharge situation?
Hi Venkat,
The BQ8050 is a generalized hardware platform for some of our gauges. Can you be more specific on which gauge you are using?
Jessica
Hi Jessica,
The battery is designed by our supplier and only provided bq8050 in the schematic. How to find our the gauge details. Attached portion of schematic for your reference .
I also want to read gasgauge using EV2400 but not able to do so.
Hi Venkat,
You will need to reach out to your supplier for this information. This gauge is not one of our catalog devices and may even be a custom gauge, in which case we cannot legally share information about it on e2e.
Jessica
Thanks Jessica I will reach out to supplier and share your response to see if they provide further information.
Can you confirm i should be able to connect EV2400 and read gasgauge details if supplier share gasgauge information?
Hi Venkat,
Yes, if you are able to connect to the gauge's smbus/i2c lines it should be able to communicate with the EV2400. However, please note that the supplier likely sealed the gauge so communication will be limited.
Jessica
