Other Parts Discussed in Thread: TUSB8042A
I have a question about the circuit that supplies power from the output of TPS2561A to USB_VBUS.
When the output of TPS2561A is turned off, the electric charge accumulated in the output capacitor is not discharged and the high potential is maintained.
Is it okay to add a 10kΩ resistor in parallel with the output capacitor?Does it violate the USB_VBUS standard?
The board was manufactured with reference to the data sheet Typical Application circuit of TUSB8042A.
Thank you and best regards,
