Other Parts Discussed in Thread: AM5728, TPS51200, , TPS51200-EP
Whether TPS51116 can be used to replace TPS51200 due to non-availability of TPS51200 for termination of DDR3 on AM5728?
Thanks for the reply
Yes, I checked but lead-time is Jan/Feb 2022.
I am assembling the board by Oct 2021. Since stock was not there I did not give clearance for fabrication. Hence I have decided to change the layout if TPS51116 can support termination of DDR3 on AM5728
TPS51200
Hi Pavithra,
TPS51200 is a LDO.
TPS51116 is a buck converter including a LDO.
If you just plan to use LDO function of TPS5116, it can support DD3 with a different layout and control.
Zhao
