Hi Team,
For the IFB spec in the datasheet, is the 0.2uA Max spec across full temp, or is that entire line item only pertinent to 25C?
Is there any data for this spec at higher VIN?
Thank you,
Jared
Hi Team,
Thank you,
Jared
Hi Jared,
It looks like the feedback leakage was only characterized at 25C. I was not able to find any further data for the spec at different temperatures or VIN. I'm not sure that IFB is dependent on VIN but would likely change slightly with VOUT.
Nick
