Other Parts Discussed in Thread: LM5117, LM3423-Q1
I want to build a constant current circuit with constant load current of 0.5A, the load impedance is varied from 10~100ohm (which means the output voltage should be adjusted from 5 to 50V). The input voltage of the power supply is 60V constant voltage. Any recommendation?
