Part Number: TPS51200-EP
Other Parts Discussed in Thread: TPS51200-Q1, TPS51200, , TPS51200A-Q1
We plan to qualify the TPS51200-EP with for our applications. However, due to components shortage, we may qualify another part (TPS51200, TPS51200-Q1 or TPS51200A-Q1). If they all use the same die, our qualification will be valid for all these part numbers.
I have found on the E2E forum that the difference between the TPS51200-Q1 and TPS51200A-Q1 is only a polyimide layer (e2e.ti.com/.../tps51200a-q1-the-difference-between-tps51200a-q1-and-tps51200-q1. Therefore, I conclude that the TPS51200-Q1 and TPS51200A-Q1 have the same die.
Could you tell me if the TPS51200, TPS51200-Q1, TPS51200A-Q1 and TPS51200-EP all have exactly the same silicon die (same silicon process, same maskset etc)? Since their electrical performances is identical (based on their datasheet), I guess that yes.
If this information is confidential, we could also discuss by email.
Thank you for your help,
Thomas
