Hi E2E Team,
Can you please explain, what "Mode"-level should be used regarding the automatic and external power-up sequencing?
Within the datasheet (table 2) there are some states within the automatic power-up where "Mode"-level is described as "Connect to high or float" and at external power-up the "Mode"-level should float. If I want to have the automatic mode (order: buck 3 --> buck 2 --> buck 1), what "Mode"-level should I use?
Many thanks in advance and best regards,
Thomas
