Hi
initial output voltage Accuracy is +-3%.
If I make 3.3V using R1 and R2, is the error rate the same?
Hi
Hi Seung,
The +/- 3% accuracy is only for VREF at PWM mode. If you run at power save mode with 2x22uF output capacitor, it will be +4%, -3%. You need to add R1/R2 tolerance to get total accuracy.
Nancy
