When using the TPS7A4701EVM at output current of 1A and voltage drop of 4V, is this enough PCB area to dissipate the 4W of heat through the bottom package solder pad and the PCB, or I have to add the heatsink attached to the package?
Will an added heatsink be efficient at all, due to theta junction to case top ?
Thank you
