Other Parts Discussed in Thread: TLV62569, TLV62568,
If I am not going to use the power good pin; are there any consideration for the layout? Should I tie the pin to ground, leave floating, tie to ground through a resistor?
Also are there any other product families that are pin compatible with at least a 1.5Amp output which I can consider? If so can you name them here?
Thank you,
HSG
