Other Parts Discussed in Thread: LM2673, , LM22676
Dear support,
We need an alternative solution pin to pin compatible for the LM2676SX-ADJ and I found that the LM2673S-ADJ could be similar with same performances (we need 3A without current limiting).
I only note that the LM2673 proposes a current limit pin and a softstart function.
On our current the LM2676 design, current limit pin is let open and softstart function is on/off function controlled by microcontroller. Can the LM2673 be controlled transparently by this LM2676 hardware without affecting the output current behavior and the enabling?
Many thanks in advance.
Julien
