Other Parts Discussed in Thread: LM5170
Dear all,
We are having EMI issue with LM5170 and would like to check with you on the following questions.
1. Is there a layout guide for LM5170?
2. May I check with you about the connection between PGND and AGND?
- In the datasheet, the EP connect to AGND with a small path and EP connect to PGND with a small path.
- In the EVM Board Guide, the EP is AGND and EP connects to PGND with a small path.
Which one is preferable to be used?
Thanks.
